I recently installed an older Welenco Pellet Stove. It worked great for about 2 weeks. Now, I'm having problems. This is what it is doing: The flame is really low, the pot does not want to fill with pellets. The auger motor was just changed. I also changed the exaust heat sensor. We had the electrical board checked and it seems to be fine. The stove won't keep the flame, it just burns down to nothing. I don't know if it's a timer problem. If you manually feed it it will burn a good flame until it burns down. Again, sounds like an auger problem, but I just replaced the auger. I don't know what else to check. Any suggestions?? Also, the stove emits a horrible smell of smoke/creosolt and blacks up the front. The door and the seals are good. I'm at a loss... Thanks for any help.
