Has any one used the Helko Tomahawk or Vario 2000 with either or both the 2300 (5lb) and/or the 1600 (3.5lb) heads. The heavy head is not currently available until December. The Granfors large splitting axe has a 3.5lb head and sells for $119. Both Helko axes can be had with the 3.5lb head for about $60. I was hoping someone had used one of the Helko axes with the 3.5lb head and could give me a review. If you have used the helko axes with both 5lb and 3.5lb heads it would be even better. An extra head sells for about $20. Heads can be switched by removing and replacing two bolts.
Thanks
Tom
Thanks
Tom
