I think this should be required reading for anyone considering a new wood burner that is supposedly a "clean" unit. The document listed in the link is the actual test method used to establish the efficiency and the emissions of any wood burning hydronic heater, open or closed system, that a manufacturer wants to list. If you read through it, you will see that the specs generated are possible only with the use of a storage medium large enough to harvest the heat from an entire load without going into idle mode. At least that's the way I read it.
I have never seen an OWB operated in that manner and I would guess that few have.
Note also that the test does not take into account jacket loses. Hmmm, think there are any of those from a tank of 180* water sitting outside at -10*???? How does that relate to actual operating conditions?
Then there's the whole thing of the cribbed/stickered wood pile at a guaranteed MC........ and the number themselves. If a person takes the btu output and the grams per hour per 10,000 btu output and factors it up to the listed emissions per million btu, they don't match. What's up with that?
Sadly, I don't know where this leaves anyone looking at the yellow or white EPA sticker while considering a new wood burner. IMHO there is no way a person using any of these units can expect to see results approximating what is shown on the test reports.
http://www.epa.gov/ttn/emc/prelim/otm15.pdf
