Heating with wood and babies
We do not have a central heating system here, just the wood and a vent free fireplace as backup.
Our Old House has two DV gas stoves as the only heat sources.
Obviously money is a factor here. There are a few options, it depends on how much electric is where you live (it's really expensive here). You can get space heaters or have electric baseboards hard wired in. You could keep an eye on the classifieds and pick up a used DV (direct vent) unit to use in place of the woodburner for a year or two (it would need a different flue but your hearth pad should work). There are also DV gas heaters that are NOT stoves. We had one at the Old House when we bought it. It was like a brown box on the wall.
The advantage to the DV units is that there is no loading. No wood, no pellets, just poof-heat. The DV stove option would look nice and should hold the value relatively well, so you should be able to resell it once you're ready to sell it. We plumbed our VF unit in this past winter in less than a day, and that included getting and filling the tank as well as running to the local hardware place a few times to have pipes cut/threaded to the exact sizes we needed (we're on propane though, and it's not hooked to our "main" tank). Electric is easy too, but I don't know about the wiring in your place. We are probably going to throw a few in the Old House before we sell, just so people aren't too put off by the stoves as the only heat sources-however we had the place completely rewired a few years ago and have plenty of room in the breaker box to add more dedicated circuits.
BTW, when we bought the Cottage, there was a central heating system. It was old and full of damaged pipes. We scrapped the pipes and heater-you might consider doing the same with your furnace if it's beyond repair to get a little extra $$ to apply towards your alternate solution.
Oh, I didn't think about trying to sell the heater and ducts! That's an idea... I have grand ideas of turning the little cabinet where the furnace is right now into a pantry.
~Rose
I like the ease of electric heat. No propane to fill, no kerosean to spill, and you still have the wood stove if the power goes out. I like the oil filled radiators the best no noise, not to hot to touch, and not to expensive.
I'm definitely eying them. I like that they'd be quiet- I DESPISE white noise, it's one of the things I like best about my woodstove! What brand do you have?
~Rose
I would get either a basic oil-filled or water filled radiator style heater. They are less hot to the touch and less likely to burn little hands. The Delonghi that BB mentioned is a good choice.
FWIW, we've used our open fireplace (now sporting an Osburn insert) since before my son was born. I worried about him getting too close to the fire when it was going, but it never seemed to be an issue. He'd get to a certain point and stop. I think the heat gets intense enough from a distance that they just know to stop instinctively. Just my experience.
Congrats, by the way!
Greg
~Rose
I can't recomend a certain brand. I actually dont own one. I don't use any electric heat or any heat besides wood for that matter. I did use a wood stove with my babies. They Knew to stay away but I still got a gate up to avoid
any accidents. I feared the toddler would be running and slip and fall onto it or somthing.
