Hi - i have an old hay barn that I’m going to covert the second floor into a home office. I can live with less than ideal heating on really cold days and I’d be fine with a design temp of 20 degrees and max heat of 65 - so 45 degree split. Here is the thing....it’s 30’ x 22’ and 18’ tall to the peak. I’d like to use the minimum insulation and the windows are all (100 sq feet) single pane true divided lights. If it helps I can do maximum insulation on the floor. I did a few heat loss calculators and I’m getting and 50,000 BTU.
I’m still learning about wood stoves so wondering if I’m naive to think I can be a 75k BTU unit, place it near where I’ll locate in the space most often, get some fans to blow hot air from ceiling back down, and wear a sweater on really cold days.
Or is this too large of a space to heat without really making sure I maximize the insulation r factors?
