I have a PS50 pellet stove that is giving me fits this year.With the feed gate half closed,On high.It will run for 20-30 minutes and shut down.If I run it on medium,It will run for a few hours and then shut down.Maybe it will go thrw a couple cycles.On low it will burn all day but never get to the point to shut off.Wont turn the thermostat off.
I can hear the stove cooling down and I go downstairs and the red light is on and the stove is cooling down.The stove will stop.Then I can push the reset button and a way it goes.It will run for a bit and shut down.
One question I have is,When I disconnect the vacuum hose from the vacuum switch and blow in it.Should it act like its plugged,or is it actually plugged?
The stove and chimney are clean.
There is no blinking light telling me the t/c is bad.Went threw that last year.I know what that means.
Thanks.
Thanks.
