I have to amend my last post - they do in fact run the high (refrigerant) pressure line in your tank, dah don't know why I said otherwise. It is still an interesting concept. 2-5 year payback is not bad - then its free (if'n it don't break).
CarbonNeutral said:So I was browsing their site (airgenerate.com) and came across the forum they have. It wasn't well used, but It concerned me that there were people on there with issues that had not been addressed by representatives from the company. Why go to the effort of creating a forum, where most posts will be of technical/complaints, and not answer them? Then their contact form script wasn't working.
I have emailed them with some concerns - we'll see if they get back. If they don't, it would really make me think twice about buying.
We appreciate your interest in our product, as well as your feedback.
1. You are right that we should be monitoring and replying to posts in the
forum. This is something that we will start working on during the next
couple of weeks.
2. For colder climates, we do have an enhanced AirTap model coming out
soon with an auto-defrost feature and a high/low pressure sensor switch,
which will help out with the unit's operation in colder climates. But if
the AirTap is going to be in an environment where the ambient air
temperature will be below 50'F for very long, most of our customers turn
the AirTap off during those colder periods and use the original internal
heating elements of their tanks.
3. The AirTap is eligible for a federal tax rebate from 2009-2010 for 30%
of cost, up to $1,500. More information on this rebate is available at
(http://www.energystar.gov/index.cfm?c=products.pr_tax_credits).
Information on state and local incentive programs is available at
(http://dsireusa.org/).
4. Thanks for bringing this information on the CGI script to our
attention, and we will look into this immediately.
Thanks, and if you have any further questions, please feel free to give us
a call or email here at the Support Center. We're here to answer those.
Jason Baker
AirGenerate Support Center
713.574.6729 option 2
[email protected]
Wet1 said:Good info Mike. Did you hookup your kill-a-watt meter to it yet?
So it sounds like this might be marginal (at best) for a family of three who all shower in the evening, is this a safe assumption? Add in a load of laundry or run the dish washer and I question if it would keep up. I know they are releasing a larger version soon (12k I believe???), although the price and performance are still unknown.
I'm beginning to think the best way to run one of these things (for me anyway) might be as a preheater for a second DHW tank. This way the AirTap would be doing the bulk of the heating, but the second tank down stream could heat any additional water as demand called for it. Example, have the cold water feeding into the AirTap equipped tank with a set point of say 125°+ F., then have it feeding into a second (smaller) DHW tank with a set point of say 115° F. Since the incoming delta into the second tank would be small, I cant imagine it would cost much in additional energy to use such a system and it would certainly have a high capacity if demand actually called for it. One down side to doing this is that you would have additional tank losses.
Wet1 said:The other option might be to plumb it into a larger volume tank so there's enough warm water for at least two or three showers. Even though the recovery would take a long time, higher demand would likely be met. But again, there's the additional tank loss with the large volume of warm water.
At least with both of these scenarios people wouldn't end up with cold showers and the bulk of the water heating could still be done using this efficient device.
With this said, I have a 50 gal. (maybe it's a 53 gal.) electric water heater and a 80 gal. SuperStor hooked to my gas boiler (indirect) configured with a valve that allows me to use whichever I chose. I also have another 40 gal indirect tank kicking around. Both the 40 and 80 gal indirect tanks are not configured like a std. electric DHW heater in their layout. I think both have the water inlet at the bottom and the outlet at the top. Could the Airtap be hooked up to one of these tanks (I don't know how the system is plumbed into a traditional electric DHW tank)? If so, what I'm thinking is I installing the 40 indirect tank on the gas boiler and installing an AirTap unit on the 80 gal indirect tank. If the AirTap on the 80 gal tank did not meet our demand needs, it could be hooked up to feed into either the 50 gal. electric tank or into the 40 gal indirect gas fired tank. Thoughts?
My other concern is dehumidification. I need to run a dehumidifier in the basement during the warmer months. Any feel for how much dehumidification you're getting out of this unit? I assume the condensate is dumped through a drain, correct? Do you think this unit would cover my needs if I was only collecting a couple of gallons a day through a traditional dehumidifier in the summer?
Wet1 said:My other concern is dehumidification. I need to run a dehumidifier in the basement during the warmer months. Any feel for how much dehumidification you're getting out of this unit? I assume the condensate is dumped through a drain, correct? Do you think this unit would cover my needs if I was only collecting a couple of gallons a day through a traditional dehumidifier in the summer?
karri0n said:130 isn't really hot enough for us. Our oil boiler is set to 160, and even then we generally do showers with the tap on full hot. No tank or storage to speak of. I haven't read anything but page 5, so hopefully this wasn't addressed earlier.
Mike from Athens said:Here are my thoughts on the preheater idea: If you were to do this, what purpose would the second tank serve? You are still using resistence heating to keep that water hot during periods of non-use. During periods of heavy use, you'll just be pulling cold/cooler water straight through, and the elements aren't going to be able to keep up any better. Are you just running regular electric heater right now?
I like the idea of having a large storage tank, but the only real down side is the increased tank loss... which is why ideally two smaller tanks with staggered temps, both equipped with AirTaps, would be more ideal.I think the larger tank options would be best. I'm thinking now maybe I should have gone with an 80-gallon tank, for the same reason as you: more storage. As far as the inlet being at the bottom, the thing mounts to the cold water inlet/hot outlet nipples to keep it in place, with adjustable rubber feet in the front for leveling. I'm sure you could rig something up to mount it to, though. It would still be attached to the hot side. You are actually replacing the 3/4" hot nipple with a new one included in the kit. The airtap heat exchanger is then fed into the hot port (it's a copper "coil" about 6' to 8' long). The thermostat bulb goes in there two. The hot water then exits out the back of this fitting through a tee.
Wet1 said:I like the idea of having a large storage tank, but the only real down side is the increased tank loss... which is why ideally two smaller tanks with staggered temps, both equipped with AirTaps, would be more ideal.
Mike from Athens said:In case anyone is still interested in this...
It's been a week since I installed the AirTap (still no kill-a-watt meter). I have turned the temperature setting up to its max (130 F). Here's the only drawback I have encountered so far...
Who???CZARCAR said:prof is currently using a nyletherm to heat DHW + built a refrigerated box for cold exhaust....still a dehumidifier of course.
Wet1 said:I contacted Nyle about their Nyletherm 1 HPWH. It would appear they are now out of stock of these units. In fact, they have licensed the design to another company, North Road Technologies. They anticipate production in March... but you know how that goes.
Hello,
Thank you for your interest in the GEYSER Heat Pump Water Heater, now available from North Road Technologies. Energy savings have never been more important, and interest in the GEYSER has been overwhelming! Because you have expressed an interest in learning more about the benefits of utilizing the GEYSER, we are pleased to give you the opportunity to review our exciting innovation. We have enclosed our brochure and our web site is now available, at www.northrdt.com - please check us out!
The GEYSER is the successor to the Nyletherm and Hot-Shot units from Nyle Corp, which have had a successful following in the marketplace since 2000. North Road Technologies has invested heavily in product development to improve the efficiency, reliability, and user friendliness of these units, and we are now ready to re-introduce this improved and advanced product. Based on our production schedules and the strong customer demand in our products, we are now accepting orders for delivery from approximately May 20, 2009, so act quickly and reserve your unit now. Please feel free to respond directly to this email, or respond to the inquiry form from the web site. Either way, you will be able to start saving money while protecting the environment in just a few short weeks.
Thank you again for your interest, and we look forward to hearing from you.
Best Regards,
Rob MontenegroNorth Road Technologies(203) 988-9338 (Mobile)[email protected]
