That's no fun. I hope spring shows up there soon. What was the room temperature like in February with the stove burning?
That's quite decent. Just stay away from those bone chilling walls.a steady 22on average, with baseboards 18
Saw dust was a common and available insulator in old homes. Also used frequently in ice houses.SO...coldest February in Ontario and So Quebec since 1889, when records might not have been as accurate. I have a feeling they used lots of hats and coats, scarves and mitten, socks and sweaters indoors that year! And lived in the kitchen. Maybe with some of the livestock to help keep things warm.....
Actually, some of the homes built around here in the 19th century are pretty darn impressive. Paper and shavings were commonly used in this area in icehouse walls to keep the ice from melting. I wonder if any homes used the same for insulation to keep heat in?
I spent 35 years living in old stone houses without AC, and the last 5 in old stone houses with AC. In a heat wave, yes, the stone house keeps you cool for the first two days. By the third it starts heating up, and then thereafter you're living in a brick oven. After the heat wave passes, everyone else's house returns to comfortable a good day before the old stone house.I will add to velvetfoot's comments. I have been in a stone cabin in 80+ degree weather and found no need for an air conditioner. The rock may feel cold but that feeling does not go away in summer.
This part is true, at least in our clime. The stone work helps knock the edge off those noon-time highs, and does keep the AC bill down. Based on our square footage, PECO was predicting we'd be paying $750+ per month during the summer, but our electric bill is one third that. My wife has 100 lights and 4 TV's on at all times.like oldman said saves on air conditioning...
I lived in a very old building once and the insulation was horse hair.Saw dust was a common and available insulator in old homes. Also used frequently in ice houses.
just stone no studded walls.the walls read from 2on bottom of wall to about 8
about 4 ft and upi'm going to have to watch who i recommend this stove to it might push you out of regular house
Careful, there. If you're talking 18th century, or really anything pre-portland, then sealing the stone could be the end of your house!Do you get a lot of dampness? Have done anything to seal ealed the stone?
I really think you should never seal and masonry unless you are talking about a foundation and you are doing it from the outside. Otherwise it usually ends up causing more problems than it is worth. And it doesnt need to be 18th century at least here lime mortar was used as late as the 1930sCareful, there. If you're talking 18th century, or really anything pre-portland, then sealing the stone could be the end of your house!
Is he really your cousin?it's only on where the floor and foundation meet about 3 inches already warned from my cousin mike homes jr![]()
