I think this is likely a closeout since it runs on 220V. Newer Geysers are 115V. I wouldn't have bought a 220V unit if I had to run a new 220V line to it, but with the Geyser I just plugged it into a 115V outlet.
How are you controlling it? Are you using the electric tank thermostats?
This- the Nyle closeout- is really interesting.
I have a stand-alone oil fired HW heater that is at the age where the tank is probably on borrowed time.
... a replacement stand alone oil-fired HW heater or a propane stand-alone HW heater? My incremental cost of electricity is 21 cents per kWh.
By the way, any track record on how these HPWH units' heat exchangers do with moderately hard water/ mineral buildup? My existing oil fired standalone HW heater makes a racket with steam pockets from mineral buildup in the tank. My water isn't hard enough to cause problems with anything else in the house, but the HW heater seems to have had buildup of minerals.
It's the older boxy type model not the newer one that sits on top of a EHW tank.
K
The Nyletherms deliver 6000 btus/hr. The optimal temperature is about 125F. Hotter than that and efficiency drops.
If you have a big tank and it is well insulated, it works very well.
