It is time for a professional Quad service tech to take care of this. It takes a special tool to press those back into place. If, that is all that is wrong. kap
I was wondering when you were going to show up.
I imagine it does. My issue would be, would I trust the repair? I'm not so sure I would.
Do you expand the tube out against the plate, Kap?As I said, depending on what is wrong. If it is just a matter of pressed tubes, I would trust it. kap
You just need to put tube back in place and use a dead punch to flare pipe again on front rack, to keep it from falling. You don't want a sharp punch so as to punch a hole in tube. Backside is usually within specs (tight fit) for no sealants. But, I would put an eye down the backside to make sure nothing is rotted. Lots of times people have used these stoves without the baffle in place, and melt or warp the pipes, which causes them to fall out. Aluminum pipes are used as that is one of the best metals for heat transfer. kapDo you expand the tube out against the plate, Kap?
I remember you from ibc sidecarFlip. Been a while. Still cruising and bruising?No problem in as much as well all go way back to IBC........
I still don't like the way the HX tubes are secured in the front bulkhead and how they are secured in the rear is only conjecture on my part. I kind of wonder what the 2 sheet metal screws that are screwed through the lower plate and (apparently) through the tubes are securing.... Interference fit is one thing, thermal expansion and contraction cycles are another animal... not something I'd do (swaged fit). Works with ammunition but even with ammunition, you crimp the edge into a cannelure to keep the bullet from physically moving in the brass.
Obviously Quadrafire realizes it's an issue if they equip their technicians with the tools to correct the issue. Next on the agenda would be a local to the OP' Quadrafire technician.
... Aluminum pipes are used as that is one of the best metals for heat transfer. kap
So all you need is a dead punch and a BFHYou just need to put tube back in place and use a dead punch to flare pipe again on front rack, to keep it from falling. You don't want a sharp punch so as to punch a hole in tube. Backside is usually within specs (tight fit) for no sealants. But, I would put an eye down the backside to make sure nothing is rotted. Lots of times people have used these stoves without the baffle in place, and melt or warp the pipes, which causes them to fall out. Aluminum pipes are used as that is one of the best metals for heat transfer. kap
Copper the best for heat transfer, aluminum next, steel last ... results from one of my boy's science fair projects many moons ago.
Good to know there is a fix...
You left out silver which was melted down for its heat transfer properties during the Manhattan Project IIRC.
I have a buddy from Tonawanda. That explains a lotWasn't going to let him near any of the silver!
Little known fact on the Manhattan Project, disposed rock sent to Tonawanda, NY but not a "health hazard"
http://www.factsofwny.com/overview.htm
You clamp or wedge them in place, and then flare. The back end is a zero tolerance fit. Or should be. Balmy 75 in my house. Running around barefoot!Getting to old to scrap. But I sure miss Stingtheives. I just go with the flow now. One question that puzzles me and thats, how do you locate the heat exchanger tubes and keep them from moving when you flare the ends to secure them?.... and, how do you insure the backend is an air tight / gas tight fit when the fromt is flared? Seems to me to be an exercise in guesstimation.........
Still burning an ugly black box and loving it... glancing across my shoulder, looks like a rocket ship across the room.....![]()
With them loose and flopping around in there, my money's on them spreading that bottom hole out. It's still under negative pressure though so air should come in. I am amazed that the stove ran when those tubes were down because of the vacuum lose at the burn pot.You clamp or wedge them in place, and then flare. The back end is a zero tolerance fit. Or should be. Balmy 75 in my house. Running around barefoot!
