if putting a pass through vent with fan is unsafe why was a link posted on this site to a company that makes and sell just such an item?
			BeGreen said:Not to get carried away here, but the bedroom door is not powered. The pipe into the room is. In the case of a fire, when you need to buy seconds to escape, closing the door will buy you time. Can you turn off the fan motor that is blowing smoke into the bedroom?
I think the point is that if you are going to put in systems that deliver warm air, then spend the extra time to install some safety systems that will protect you in case of an emergency. Some of these options are:
1) smoke and/or CO detector shut off of powered fans
2) put a fan switch in the room that is being fed by the fan
3) if hard ducted, consider adding a fire damper to the pipe
GrantC said:More to the point: if a passthrough is so unsafe, can I assume that everyone sleeps with their bedroom doors closed? After all, if a 6" round hole in the wall (roughly 9.5 sq in) is that dangerous, a 30" door (2340 sq in) must be 246 times more dangerous - right?
Please, someone give me a non-hyperbolic reason why a passthrough is such a no-no - and remember that bedroom door.
-=[ Grant ]=-
Marty S said:What is your logic of putting a 6" hole (1/246 the size of the existing door, by your calculation) in the wall to make your bedroom warmer?
Why not try heating your bedroom up with the door open when your burn your stove during the day, add a small fan on the floor to blow cooler air out and then discontinue the fan and close the bedroom door on retiring?
As the fan forces cooler air out lower in the bedroom, it will be replaced by warmer air from the ceiling area in adjacent heated room where the stove is located.
GrantC said:Marty S said:What is your logic of putting a 6" hole (1/246 the size of the existing door, by your calculation) in the wall to make your bedroom warmer?
Please see the diagram on the first page of this thread. We do that now - but the air in the hallway is significantly cooler (by 10-15 degrees) than the air in the family room, so the spare bedroom doesn't get terribly warm. Tolerable, but not warm.
I'm hoping that bringing the much warmer air near the ceiling of the family room into the spare bedroom will result in a marked improvement.
-=[ Grant ]=-
amitysanimal said:I have a similar problem. I live in a 76' mobile home and I'm having trouble getting heat down a hallway to the master B/R and bathroom. I have a fan in the top of the doorway trying to move the warm air down the hallway but it doesn't seem to work that great.
My Uncle told me to put the fan down on the floor and push the cold air into the room with the stove, and the warm air will flow down the hallway, replacing the cold air. He said its easier to move the cold air than it is to move the warm air. Does this make any sense? Should I try and put the fan down on the floor and move the cold air?
amitysanimal
HeatsTwice said:Has anyone used the outside air intake of their wood stoves to draw cold air from the back of the house by using a (somewhat) long supply tube running through the basement or rafters? IMHO, this would be a great way to force circulation from the stove to a cold part of the house without the use of any blowers, fans or vents. An added bonus would be to put in an inline flapper vent which could be closed in the event of a chimney fire.
I have searched all of these forums and not encountered any one mensioning that they had done this.
Marty S said:HeatsTwice said:Has anyone used the outside air intake of their wood stoves to draw cold air from the back of the house by using a (somewhat) long supply tube running through the basement or rafters? IMHO, this would be a great way to force circulation from the stove to a cold part of the house without the use of any blowers, fans or vents. An added bonus would be to put in an inline flapper vent which could be closed in the event of a chimney fire.
Just a couple problems with that idea:
1. A long tube to the back of the house is not "outside air", unless you mean "from the back of the house" outside.
2. The long tube would not warm the cold part of the house it came from, without a fan or blower, since warm air rises.
3. Most main level (first floor) wood stoves don't need outside air especially when they're dialed down to prevent over firing.
FYI: These, and other, reasons may be why you have not found anyone doing this.
Aye,
Marty
fish said:how about a bathroom vent fan set up with 4 or 6 inch flex going to the bedroom. so as the air comes off the stove the vent fan in the ceiling sucks the hot air up and moves it directly to the bed room. i have been using this system for about 2 years and it seems to be doing a good job. i have about 60 feet of flex vent in my attic that goes from the stove to the bedroom via a heat vent in the ceiling. youll also need to cover the flex vent with insulation so no heat is lost. according to the thermometer my bed room is 5 deg colder than the room with the stove . i have a 1700 foot house and am able to heat the house with a quadrafire 2100. only rated for 1500 max. but the house is never cold.and i live in western ny were its always cold night temps about 10 deg or less most of the time. i draw my warm air 3 feet from the stack going through the ceiling.
HeatsTwice said:Marty S said:HeatsTwice said:Has anyone used the outside air intake of their wood stoves to draw cold air from the back of the house by using a (somewhat) long supply tube running through the basement or rafters? IMHO, this would be a great way to force circulation from the stove to a cold part of the house without the use of any blowers, fans or vents. An added bonus would be to put in an inline flapper vent which could be closed in the event of a chimney fire.
Aye,
Marty
1) True. Sorry for not being more specific.
2) Very true. I didn't even think of that.
3) Need it or not the stove I have (Napoleon 1900) has one - which I don't use. I just thought I would use it to move cold "back of the house" air out of the house, rather than from all over the place as I am doing now.
Thanks
