Heat Commander Big Enough??
330W blower (HC @ 0.2” wc) at say 12hrs runtime for 30 day month at $0.30 = 330x12x30/1000 =$118.8 added..
I'm sorry, but your math is not mathing.
330 watts X 3 hours = 1kWh roughly (you are billed by kilowatt hours) = .30 cents in your case
If you are running the blower 12 hours a day, that's .30 (1000 watts = 1kWH per above) x 4 = $1.20 for every 12-hour period
$1.20 every 12 hours X 30 days a month roughly = $36 dollar a month added to your electric bill.
In actuality it's a little less because over a 100-hour period I'm adding 1kWh to my math. And as brenn pointed out, the motor is not going to be running at a full 330 watts all of the time too. My guess is it will add roughly $20 - $30 a month to your bill.
Reactions: GG Woody
The sad part is $100+ to run a 1/3hp blower motor doesn't seem out of the question with our electricity rates 😄. $20-30 sounds more reasonable though.
For anyone interested: I extended the wires for the plenum RTD and moved the RTD to the very top of the plenum today. I previously had it about 2/3 of the way up the plenum because thats as far as the wires would reach. The blower runs for longer during the "on" cycles now. "Off" cycle times remain similar, maybe slightly shorter. This is based moving the sensor from one location to the other every 10 minutes and timing cycle times. Fire is getting toward towards the last 2/3 of its burn cycle so times were slowly changing due to that during my testing window. Fire was also only started 2hrs before tesring in a luke warm firebox so not ideal testing conditions. Ill test again sometime if I get real bored.
Seeing as heat rises and the top of the plenum is significantly warmer to the touch than the bottom of the plenum, it makes sense that you would get more run time with the sensor near the top.
Reactions: sloeffle
Lamppa wants the blower switch mounted up high in the VF plenum too...
The more I learn the more I understand why people are willing to pay so much for the lamppa units.
I wish I had bought one back in 2012 when I put my old Yukon Husky in...turd.
Oh well, it was a long and winding road getting to the VF, but I got there, and learned A LOT along the way...
Woops, you're right about the math. Forgot to multiply $0.30 per kWh
330x12x30x0.30/1000 = $35.64 extra per month.
My bad. Well that's more comforting lol. Still not desirable.
Doesn't this only apply in convection though? Otherwise, if that were the case, you'd be hotter further from the source, which we know is not true. I would think that the most heat is nearest the source, especially under forced air movement. Perhaps I'm not thinking of it correctly though. Maybe try a grill probe thermometer at each location and see what the difference is?
Doesn't this only apply in convection though? Otherwise, if that were the case, you'd be hotter further from the source, which we know is not true. I would think that the most heat is nearest the source, especially under forced air.
I see what you're saying. I wanted to get the sensor directly in between the air exchange tubes but couldn't figure out a way to position it there. The plenum is hot to the touch near the top and only warm to the touch near the base. If I ever get a probe thermometer I'll take some readings.
