HI All,
I have noticed from time to time Im getting some faint smells of smoke in the house from my stove. Typically its upon reload once it gets going and is gassing off. I went over to my stove when i noticed the smell and if i put my nose near the side door handle I can smell smoke. I made sure there was nothing from the front door to rule that out and its clearly from the side door only. I noticed that the top of the gasket made it appear from the factory they didn't align the door right, it was a little skewed. So i ordered a new gasket and re-aligned the door thinking that would fix it. That didnt work and I still smell smoke from time to time. Attached is a picture of the gasket, the side door is a tongue and groove style. In the area i circled red which is along the side of the door you can see that section is not really compressing when the door closes (theres no groove mark pressed in like the rest of the gasket).
My question is can a side door gasket leak so it causes smoke when the stove is burning hot or should a leaking gasket only ever allow more air into the firebox but not the other way around? Basically is it possible there is a draft issue pushing through a weak spot in the gasket? For my setup the stove vents into an exterior chimney, the straight run of liner from the tee up is 12/13 feet and then from the tee into the house down to the stove is another 5 feet. So in total about 17ish feet of total run. Thanks
![[Hearth.com] Hearthstone Manchester 8362 side door gasket issue or something else? [Hearth.com] Hearthstone Manchester 8362 side door gasket issue or something else?](https://www.hearth.com/talk/data/attachments/304/304247-894829cd0eb26b42592dc09c7ce727e8.jpg?hash=FQqAXT4MVZ)
![[Hearth.com] Hearthstone Manchester 8362 side door gasket issue or something else? [Hearth.com] Hearthstone Manchester 8362 side door gasket issue or something else?](https://www.hearth.com/talk/data/attachments/304/304257-a75b805eb35f4f64ab53a4d914d3b53e.jpg?hash=vUUKyZh4om)
![[Hearth.com] Hearthstone Manchester 8362 side door gasket issue or something else? [Hearth.com] Hearthstone Manchester 8362 side door gasket issue or something else?](https://www.hearth.com/talk/data/attachments/304/304274-48c1c44a19011d3797c01ada08c265e8.jpg?hash=qUWoxs9DEM)
![[Hearth.com] Hearthstone Manchester 8362 side door gasket issue or something else? [Hearth.com] Hearthstone Manchester 8362 side door gasket issue or something else?](https://www.hearth.com/talk/data/attachments/304/304411-0241ad9813fdfe68a986465a04b5f922.jpg?hash=Ib820RsHUt)
![[Hearth.com] Hearthstone Manchester 8362 side door gasket issue or something else? [Hearth.com] Hearthstone Manchester 8362 side door gasket issue or something else?](https://www.hearth.com/talk/data/attachments/304/304419-3e88077242462caeffc2be08f4990628.jpg?hash=4ASArjihdt)
![[Hearth.com] Hearthstone Manchester 8362 side door gasket issue or something else? [Hearth.com] Hearthstone Manchester 8362 side door gasket issue or something else?](https://www.hearth.com/talk/data/attachments/304/304721-ec6fdee6496b3ef0c9a531cb756e7937.jpg?hash=F-mcavrRjY)
