There is a Hearthstone Heritage that's 3 years old for sale for $1300.00 . How does everyone that has one like them. I will be heating 1300 sq ft two story in north west cal. Lots of fir and oak . I am using a 80's Orley now.
I might have a chance to trade the Buck 91 for one. I don't think it's used very much, and maybe with some lube, the hinges would last. Maybe I could figure out something to improve the latch system...The tiny hinges are soft and the doors were sagging, repair meant a total stove tear down into little rocks
I don't think this guy burns much, so maybe the holes aren't wallered out too bad yet. Maybe I would try some dry graphite spray lube; It's possible that the oil runs down when the stove gets hot, and doesn't last as long...I lubed the hinges and latches regularly. 90 weight oil worked best but had a smell. The hinge pins are very small and hard steel, no wear. The cast iron frame of the stove is drilled for the hinges and that metal wears out against the much harder steel pins.
Dry graphite (key lock lube) would be my choice too.
Graphite is a great dry, high-temp lube. Wonder if one could drill out the cast and sleeve the pins?
I asked a Hearthstone tech about the latches and he told me most of the issues were replacement gaskets were sometimes too tight so it put too much stress on the softer cast parts. He recommended smoke testing the gaskets at operating temp rather than dollar bill testing cold.
Get their gasket. If you go to any stove shop or hardware store and get 3/8th it may be high density and end up being too tight. I bought some before I had that conversation from a stove shop but have no idea now how to tell what it really is so I will be ordering from them. I personally like the graphite suggestion above too. Seems like good insurance to me. On my old stove I think I am going to round off the leading edge of that door side latch too. Can't hurt to dull that thing a little bit.Ah! Great to know somebody at the company recognizes this is a problem. Now if they would only do something about it?
I busted the Tribute stove I used to have big-time as a result of this problem. Latching the door over that too-big gasket eventually wore down the lip in the cast frame to where it wouldn't hold the latch on the door anymore.
Did the tech have any suggestions for what to do when you do need to replace the gasket?
Or drill bigger, fashion some brass pins, and keep them lubed well. Maybe have a machine shop drill them bigger to make sure everything is aligned properly, if you're not equipped to do the job right. I'm a believer in OEM gaskets. http://www.hearthstonestoves.com/store/accessories/heritage/gasket-kit-90-58210Graphite is a great dry, high-temp lube. Wonder if one could drill out the cast and sleeve the pins?
Can you order directly from Hearthstone? The 3/8 that caused my disaster with the Tribute was sent to me by the dealer, though I don't remember what name it had on it.Get their gasket. If you go to any stove shop or hardware store and get 3/8th it may be high density and end up being too tight. I bought some before I had that conversation from a stove shop but have no idea now how to tell what it really is so I will be ordering from them. I personally like the graphite suggestion above too. Seems like good insurance to me. On my old stove I think I am going to round off the leading edge of that door side latch too. Can't hurt to dull that thing a little bit.
Thanks very much for that link, Woody. I may just get that now so I have it on hand if and when.Or drill bigger, fashion some brass pins, and keep them lubed well. Maybe have a machine shop drill them bigger to make sure everything is aligned properly, if you're not equipped to do the job right. I'm a believer in OEM gaskets. http://www.hearthstonestoves.com/store/accessories/heritage/gasket-kit-90-58210
Yea, I would like to see that they have done something to address the issue too. Some sort of serviceable receiver on the stove side would be very smart for sure. I wonder how many have completely failed like yours and Gyrfalcon's? I don't know much about cast iron but I also wonder if they had a bad batch of frames that was a little soft?The tech blaming the gaskets for their poorly engineered latches? That's rich. I'm sure he was told to say that, it certainly is not the gaskets. I used the OEM gasket for all 30 cords in my stove and the hinges latches were still failing. At least they know it is a problem and the weakest link on an otherwise good stove.
I decided to look and my stove side latch receivers seem to be in very good shape on my old stove. I am honestly surprised a little. I will try to take some photos this weekend when the light is a little better of the new and old stove. The build date on the old one is 3.2004. Really where the latch does its work, there looks like very little wear, but again, I have never replaced my gasketsI did not get complete failure, or catastrophic failure. My hinges got very sloppy and the door catch worn razor sharp and thin. I recognized the degradation and the lack of durability in the design so sold the stove before catastrophic failure. The used market is quite good for a modern production hearthstone. They look awesome.
Replaceable adjustable hinges and latches. Or at least serviceable would cost extra money for production but lets remember that this is a premium stove with a price point at the top of the list.
Some of it, I'm sure, has to do with how frequently those doors get opened and shut. Trying to heat too much space with way too small a stove in a cold state-- and being clueless about how to keep a fire going right the first couple years -- meant that my Tribute got way more wear on the latch than it could tolerate since I was opening and shutting that door many, many times a day..I decided to look and my stove side latch receivers seem to be in very good shape on my old stove. I am honestly surprised a little. I will try to take some photos this weekend when the light is a little better of the new and old stove. The build date on the old one is 3.2004. Really where the latch does its work, there looks like very little wear, but again, I have never replaced my gasketsMore to come. OP, don't give up on us yet! Everyone here on this site is awesome!
P.S. I looked at the hinges too. Not visibly egged out. There was likely the same amount of wiggle on the door side as there was on the stove side. X2 there is a little sag and really that is on the front door only. Still would be better if there was a softer pin that is easily replaceable rather than a very hard pin wearing on softer cast part that are very hard to replace.I decided to look and my stove side latch receivers seem to be in very good shape on my old stove. I am honestly surprised a little. I will try to take some photos this weekend when the light is a little better of the new and old stove. The build date on the old one is 3.2004. Really where the latch does its work, there looks like very little wear, but again, I have never replaced my gasketsMore to come. OP, don't give up on us yet! Everyone here on this site is awesome!
Not denying the weakness but I do wonder if graphite from day one makes a difference? I would have put a Tribute in my basement if I could have found one at the right price. I got tired of shopping and dealing with the public and decided to get something I knew!Some of it, I'm sure, has to do with how frequently those doors get opened and shut. Trying to heat too much space with way too small a stove in a cold state-- and being clueless about how to keep a fire going right the first couple years -- meant that my Tribute got way more wear on the latch than it could tolerate since I was opening and shutting that door many, many times a day..
