First, I want to address that I have absolutely no intention of using (or opening) the left side door this heating season. The front door will work fine for me (I'll explain why below).
Since some of the ceiling joists and roof rafters were already cut when the old prefab fireplace was installed. I decided to use the existing hole to run my pipe (double wall inside and triple wall in the attic).
The only clearance I could not follow was the left side of the stove.
So, I built a 4' 6" brick wall, using solid 4 inch brick pavers for wall protection. I thought this would be sufficient…wrong.
The left side of the stove is 8 1/4" away from the brick. If you include the 4" brick, I have a total clearance of 12 1/4" from a combustible wall.
My concern arouse last night when I had stove running at full capacity. I put my hand directly on the brick (facing the left side of the stove); the brick was so damn hot I could barely keep it on the brick for more than a split second. If the surface temp is this hot, I imagine 4 inches of cement or mortar will make much of a difference. If I run this stove hot all winter, I'm afraid the wall catch on fire.
I hate to cut additional ceiling joists and rafters, and then poke a new hole in the roof. Plus, I'm running out of time.
I was thinking about buying a piece a sheet metal for the left wall and screwing it into the mortar joints for this heating season and then fix the clearance issue in the spring.
Am I just over paranoid about the surface temperature on the brick? What are your thoughts on using a wall shield for this heating season; should I bite the bullet and move the chimney now?
