mdocod
Burning Hunk
Any new opinions on this question from a few years ago now that the Green Mountain stoves have a longer record?
Specifically, I'm trying to decide between a Blaze King Ashford 30.2 and a Green Mountain 80. Both designs are wife-approved. This will go on a hearth in an alcove on an exterior wall to replace an open fireplace. It's a first-floor family room with a 20'+ ceiling. The house is 4,000 sqft, open design, with upstairs bedrooms and a stairway/catwalk in the middle. We'll have a 25-foot Class A chimney going straight up inside a chase.
We'll use the stove in three seasons (Northeast U.S., mild spring/fall, cold winter) to supplement forced-air geothermal heating. Our firewood is basically free. I understand that the GM 80 takes a more expensive 8" pipe, but that's not a big factor for us.
Are they equally safe to run unattended at medium-high at night, and which would produce more heat? Would both produce flames if run at low-medium while we're sitting near them? How big of a plus is the thermostat on the Ashford? Could both run on 2x/day loading? How do fan noise and ash cleanup compare? Thank you.
The GM 80 is a 600lb hybrid stove optimized to burn at moderate rates, balancing primary, secondary, and catalytic combustion with high mass to slow down burn rates and spread out the heat output over time compared to traditional steel non-cat stoves. Burn cycles in this stove can be as short as ~6 hours when burning softwoods very fast, or as long as ~24 hours when burning hardwoods slow. On average, this stove is well suited to an average 20-30K BTU/hr burn rates.
The Ashford 30.2 is a 500lb catalytic stove optimized to burn at low rates, balancing a slow primary fire / smolder with a heavy dose of catalytic combustion and thermal mass to slow down burn rates and spread out heat output over time even more than a Hybrid stove. Burn cycles in this stove might be as short as ~8 hours when burning softwoods at the highest speed available, though this is not where this stove shines. 18-28 hour burn cycles with 12-18K BTU/hr burn rates is the sort of behavior most users of these stoves are looking for.
I think the GM 80 is much better compared to the likes of a BK King, both being 8" flue, and both having a similar BTU/hr operating range, with the BK offering that output over longer burn cycles made possible with an even larger fuel box. For a 4000 sq ft home, I would probably avoid the Ashford, I don't think it's well suited to the BTU/hr that you could likely make use of in a house that large. The GM 80 is a better fit to the sort of BTU output that is meaningful for a large home.
