Huntindog1
First pic doesnt look like very good coal bed. Doesnt look like your stove is full.
You will have to get a feel for your wood and when to close the air down.
Close the air down in 1/4 ways increments then wait for a few minutes then lower the air down again 1/4 ways like I mentioned its a feel you will learn on how long to wait between each increment you shut down the stove.
Sounds like your wood is border line usable. As in it will burn but its causing frustration. Good kindling will help and using a good bed of coals.
Rake those coals forward so you have most of your good coals in the front by the door. Load the wood in the back all the way to the bottom of the stove. In the back is where to load the big stuff and load stuff all the way up to the top as close to the baffle or tubes. Picking pieces to fit is an art form LoL. Then load a second row with a little smaller stuff then that row closest to the door load kindling that will sit on the bulk of the raked forward coal bed. The air comes in there in the front and if at first you have the dorr cracked it will get the kindling fired up fast on hot coals. You have to do all this stuff as your wood is sub par border line. Really 18% or less is what you want. I never did like 20% stuff.
Your leaning dont worry we all have been thru the learning curve.
Look at the pics in this posting.
https://www.hearth.com/talk/threads/rake-coals-forward-and-stove-start-up-pictures.80659/
