In anticipation of the new stove ( Enviro Kodiak 1200 ) here are some pics of my hearth. It measures 58" wide 49" deep at its deepest and 40.5" deep where the chimney juts out. I'm pretty sure I'm good Width wise, but to get the 18" from the loading door ( canada) I may have to add on. It is in a basement and the carpet is laid right on the concrete floor, we are planning a reno so I'm thinking for the time being I'll cut out some carpet and lay down some ceramic tiles just to meet code. That should do ; am I right? Pre inspection is Tuesday so I'm sure they will tell me what works and won't. The hearth size is within spec according to the manual but not with the chimney sticking out there; maybe.
I plan to put in a dri-core ( home depot 2x2 sq ) subfloor which is about 2" high; and remove the carpet; maybe tile ;maybe laminate will go back. or some combination
So would you:
1. extend the brick work ; I haven't done brick work, but hey its not load bearing so I'd give it a go. I do like the brick.
2. remove the brick and build up a suitable floor pad with durock and tiles
3. build an extension and cover the horizontal brick with a new tile to make it all one.
4. 3 and tile the chimney to match
5. 2 and tile the chimney to match
Thanks for any thoughts!
Edit: I'd like to add that I DO have a doggie; she is up laying by one of the electric ( ugg ) heaters with no fire going
So would you:
