Heard the saw running (cont.)...
Stax
941
Southeastern PA
They guys said that I couldn't take anything until the saws quit running. So around lunch time the buzzing sound ceased and I made a bee-line around the corner. I was hoping for a much bigger scrounge but I took what I could get. Some box elder (holy crap this stuff is light and spongy), Mulberry (very heavy and wet) and Cherry.
  • Heard the saw running (cont.)...
A box elder split and a pile o' color.
Nice score Stax, they all add up. How does the Mulberry burn?
zap
zap
Very good once its dried.Very close in density & heat value to Red Oak.Dries much quicker,around here its good to go in 12 to 18 months,Red/White Oak is 2 yrs minimum,unless its standing dead - that can bring it down to a year if in spot that gets plenty of wind.
Very good once its dried.Very close in density & heat value to Red Oak.Dries much quicker,around here its good to go in 12 to 18 months,Red/White Oak is 2 yrs minimum,unless its standing dead - that can bring it down to a year if in spot that gets plenty of wind.[/quote]
What is a good way to check besides a moisture meter to see how dry a dead standing tree is? Will be getting some dead oak standing for about 12 months now but how do i know how dry it is to let it sit for another 12 or doe s it need laonger.
What is a good way to check besides a moisture meter to see how dry a dead standing tree is? Will be getting some dead oak standing for about 12 months now but how do i know how dry it is to let it sit for another 12 or doe s it need laonger.[/quote]
If the tree's been standing dead a few years you usually get lucky & most everything up to 5"-6" diameter can be dry enough to burn well immediately.Look for silver-grey outside with little or no bark remaining & 1 or more long vertical cracks on upper tops & branches.As you get further down the trunk the moisture content can be much higher,you'll notice this in the darker wetter looking chips & pieces being heavier.Those can take from 1 to 2 yrs to dry once split & stacked.I let all my wood set for 2 yrs minimum,except for that which is obviously drier when first cut.Its stacked separate from the wetter stuff.
Some woods are drier than others - Maples & Ashes dry quickly,same with Hickories,compared to usual slower Oaks.
