Head spinning: pellet or wood?
Ever consider getting a coal burning insert? Less work like a wood burner, more consistent and steady temps, cost is comparable (@300/ton) , and you could carry smaller quantities from your stash via a coal hod (carry what you can handle).
People are still allowed to burn coal? It's portrayed in the media as a "dirty" fuel that releases diabolical amounts of carbon.
You guys are throwing so many creative choices at me that my head is spinning again.
Yup, a friend has a coal burner in his basement, he heats with.
Ok, the post about coal gave me another idea. Do you maybe have a walkout basement with still some room in there? Maybe you could get a wood furnace. Pay the firewood guy some extra to stack the wood outside and in the fall you grab a little 4-wheel hand-cart and transfer the wood from the stacks next to the furnace. Minimal lifting required but you can still burn wood.
Another creative idea. Unfortunately I don't have a walk-out basement. Anything I store has to go down a flight of stairs.
Propane: Is propane as expensive as oil, and does it require a giant tank right next to the house.
Here is the latest Vermont fuel price report. According to their calculations propane is currently more expensive on a BTU basis than propane: (broken link removed to http://publicservice.vermont.gov/sites/psd/files/Pubs_Plans_Reports/Fuel_Price_Report/2013/October%202013%20Fuel%20Price%20Report.pdf)
If you get a new system and have a different average propane price in your area the numbers can shake out different for you. However, in any case both are more than wood or pellet.
My grandparents heated a lot with wood, they stored it in the basement. No walkout/bilco doors, so my grandpa would take out one of the windows every year and use a chute (kind of along the lines of a conveyor, but without it moving) he built to get it in easier than carrying it down the stairs.
I've been thinking about the very same idea. I think the two things left on my to-do list for now are to investigate mini-split heat pumps and to figure out if there's a flush insert that fits my small firebox.
I wanted a pellet stove for the bagged pellets that were neat and clean. I also wanted emergency heat that required zero gas/electricity or back-up generator if the power went out (Feb2013 blizzard). I picked up an used EPA rated wood insert and CSS at least seven cords of wood just in case. In your situation either may be the correct answer to your needs.
Not sure I trust that conclusion :)
;lol
Ok, it is propane more than fuel oil.
Reactions: gyrfalcon
Annual costs: Fuel + maintenance + service seems like a wash between pellets and wood, but I fear I'm overlooking something expensive.
With pellets your buying into a utility that has no substitute. They ask more you pay more. With wood when your broke you can scrounge wood, when you have money you can burn Bio Bricks and have the same convenience as pellets . Pellets and Bio Bricks need to be stored inside and wood can spend all it time outdoors until you burn it. So I don't see where the cost can be compared as close to the same.
Besides with a pellet stove if you have no power, you have no heat. I have always voted to stay warm regardless of financial status of other forms of utility.
This forum can be dangerous for many dealers, because you as a buyer are more informed and they become unable to sell you a bag of goods. If the dealer embraces your knowledge, then he will be a better dealer to trust with your purchase. You shouldn't trust everything you read or everything a dealer tells you. There are truths that you will hear from all sources that you will need to put together for yourself. But know that this site has no one with any other interest then to help you through your decisions.
Lots of people make'em. Lot's of people sell'em. Hearth.com shows you how to use'em.
The only problem I have with my pellet stove is that in an extended power outage I can't burn the coffee table in it. >>
Has anyone mentioned that flush wood inserts need a blower too? I have neither a flush insert nor a pellet stove, but if noise is a consideration, I think both make noise to some degree.
I'm new but have read many posts. Thanks to everyone for being so informative, helpful, and polite to the uninitiated. Here's my story:
- 1,400 sq. ft 2 story home
- oil heat
- live in New England
- want to replace oil as my heat source
- propane and natural gas aren't options
I originally investigated free-standing pellet stoves with small footprints (such as St. Croix Element) to minimize loss of space in my small living room. I avoided wood burning stoves because the black chimney pipe is too obtrusive for the room. After an in-house visit from a dealer, I now realize that even small pellet stoves require more space than my room can accommodate. I do, however, have a fireplace in the room and won't lose any space if I place an insert into it.
An insert means that I could go with either a wood burning or pellet insert because I no longer have to worry about ugly stove pipes. Here are my worries in choosing between pellets and wood. Of this list, what should I be focusing on?
Fuel: Pellets seem to be widely available now. I don't ever plan to cut my own wood and would have to purchase it. It's doubtful that I can find wood dry enough to start burning now.
Transporting inside: I have a bad back. Lugging 40 lb bags of pellets is an unpleasant thought, but at least everything is inside once I'm done. Walking in the freezing cold repeatedly to a pile of wood in the yard doesn't seem fun.
Storage: I'd have to store pellets in my basement, making transportation worse. I have no wood shed, and unless you think it's kosher to store wood in an unfinished basement, I can't think of a good way to keep wood dry in winter.
Heat: The dealer told me that a wood burning stove would make my living room feel like an oven. I tend to like it cool and would find an 80 room unpleasant. I'm under the impression, though, that a wood stove can heat an entire home better and more quickly than a pellet stove.
Heating patterns: I tend to turn the heat low or off during the day and then turn it up when I get home at night. I don't know which stove better matches this pattern.
Maintenance: The pellet forums and dealers describe pellet stoves as high maintenance relative to wood burning stoves. If you add stove maintenance to the transporting, storing, and loading of fuel, I can't figure out which stove requires less labor.
Models: If I buy a pellet insert, it will be the St. Croix Ashby because the dealer is 1 mile from my house. If I buy a wood insert, I'm lost. I really like the looks of flush inserts but don't know if they throw enough heat to reach upstairs. And I can't figure out what the value of a hybrid is.
Smell: A neighbor burns wood. It's smelly and smoky. I don't want to pollute the neighborhood and can't determine which type of stove will annoy the neighbors less.
At the moment I'm leaning toward wood, hence posting in this forum. Thanks for reading something so long.
Disclosure: I have never owned a pellet stove.
If I were you I would go with wood. It costs about the same or less than pellets, but probably not more. If you are buying firewood, you can buy one year's worth in advance and store that in your yard. Cover just one cord of it so you always have dry wood to burn. Wood generally produces more heat than pellets, so that's a plus. You can burn for up to 12 hours with wood, and you will light fires at night anyway. Wood makes a nicer fire to look at, in my opinion. Maintenance with wood is less, anohter plus. Wood requires no power (a small plus). Smell, if it exists, is generally good. If you burn the stove right, there is little or no smoke smell, except perhaps when you are just starting the fire. Some woods smell good when burned. My neighbors seem to like the smell of my wood stove fires, to the extent that they smell them at all. If you are willing to buy your own firewood, the only real plus I see from a pellet stove is that you can set and control the temperature more easily. The other advantage, direct venting, doesn't really apply in your case since you have a fireplace and chimney already.
I have both, so here is my take.
Pellet stove=convenience
Wood=commitment, but with the ability to run without hydro. We have had three outages this fall, all over 1 hour with the longest over 3.
I had a Harman advanced Pellet stove in my previous house and I have 1 wood stove insert and one wood/coal standalone stove in my current house. I have my wood stove insert installed last month. I don't have good size of yard and I don't have source of free wood. Pellet stove is like a furnace, you can set the temp and let it go for a day or two. However, the price of pellet may change by the supply/demand. The reason I chose wood insert is because I like to see/play the real fire and I can choose whatever I want to burn with the stove. Kids like to make smores inside the house too. (with the stove door opened) There are many types of biobrick for wood stove in the market now so burning "wood" stove is not that dirty anymore. They should be easy to store. The price biobrick should be inline with the wood pellet. If the price goes up, I can always go back and burn wood....The only complain I have is the blower for my jotul insert does not kick on until the stove reach certain temp. It usually takes good 40-50 minutes for the blower to start before the heat can be spread to the room. Not sure about other wood insert. My 2 cents.
That is by design. First the stove needs to get hot enough to ensure proper combustion before the blower can turn on as it will invariably cool down the stove. I don't have a Jotul but 40 to 50 minutes to reach temp sound excessive, however, even from a cold start. My PE Super insert takes about 20 minutes before the blower kicks in. How do you start a fire?
Ah yes, flush inserts with high WAF to boot! That's exactly what I wanted when I started looking for inserts (5 or more years ago). The ones I liked the most were Lopi flush face Cape Cod and and the VC Montpelier. They really look great in the fireplace. Eventually you learn what makes a good stove/insert is NOT just a pretty face.
When I went looking more recently (after I owned an insert for almost 2 seasons) dealers tried to woo me with the Jotul Rockwood and the Quad Grand Voyager and others, but this time I knew better.
Thanks Grisu.
I don't think I am lack of fire when I start. I mean....it burns pretty well. After 20 minutes, I can feel heat outside of the glass. I think it is just the way the snapstat is designed/configured on the Jotul c450. The location of the snapstat is at the edge of the firebox which takes longest time to be heat up.
Thanks Grisu.
Yeah, ours is located on the bottom left side of the stove so it takes a while from a cold start to kick on. We can have a 700 degree top temp and the blower won't be on yet. On the other hand, it will still be running with the top temp cool enough that it's not registering on the thermo so it's basically blowing a cool breeze!
If I go with a flush insert, I'm struggling to find something that will fit. The dimensions of my fireplace opening are: 35" wide, 30" high, and 20" deep at the opening. The back, however, is only 23" wide and 15" deep. So far I've found only 4 stoves that might fit:
- Hampton HI200
- Regency CI1250
- JOTUL C450
- Neo 1.6
Are you aware of any others? Are all of the above too small to be able to heat a 1,400 sq ft home to 60-65 degrees?
- Hampton HI200
- Regency CI1250
- JOTUL C450
- Neo 1.6
JOTUL C450 has a spec of 1,600 square feet of heating capacity. If you run the stove 24/7, I don't think you will have problem heating 1400 sq ft home to 60-65 degree. Again, it all depends on the fuel(type of seasoned wood) you have and the air flow of your house.
- Hampton HI200
- Regency CI1250
- JOTUL C450
- Neo 1.6
All of those stoves are rather small with a firebox of less than 2 cu ft. You will only get burn times of 5 to 6 hours with those. They may get your house to the temps you are looking for but struggle to maintain it there. Unless someone wants only a supplemental heater we recommend going a size bigger to the 2 to 2.5 cu ft range. I know you want an insert that does not take that much space but I would look into non-flush inserts. Many stick out only a few inches; hardly a problem even with a small living room. How deep is your hearth in front of the fireplace (E)?
In addition, when you say it the back is only 15" deep what do you mean by that? Is that the height? A picture may help. Can you use that scheme to measure it?
(broken image removed)
(broken link removed to http://www.woodheat.com/how_to_measure.php)
