Theres something wrong if it looks like that after cleaning....
I'm willing to listen to theories, Jack. Again, I simply use a clean paper towel with cold water. When the glass is wet, it looks clean. When it dries, that haze never leaves. Definitely seems odd to me. Who knows...maybe I have a defective piece of glass. We'll see what happens after I try the Rutland glass cleaner.
The haze and the ash buildup on the window or your pellet stoves is not a defect in the glass or the operation of the stove. It is a normal byproduct of the material we burn. Consider the condition of the inside walls of your pellet stove when you clean it...completely covered in ash and perhaps some creosote. Your window is being impacted as well. I've now had my stove for 17 months and every week during burn season I clean the glass. Some weeks are worse than others depending on how hard the stove has had to work. Same with the ash buildup on the interior.I have the exact same issue on my stove's glass.
. I've been dealing with this haze issue since the day one and I also wonder if the glass is defective--very disappointing.
Jerry.
The haze he is talking about is there right after he cleans the glass (if I understand the posting correctly) If that is the case, then the haze isn't a normal condition because he hasn't burned any pellets on the freshly cleaned glass. His cleaner isn't doing the job.The haze and the ash buildup on the window or your pellet stoves is not a defect in the glass or the operation of the stove. It is a normal byproduct of the material we burn. Consider the condition of the inside walls of your pellet stove when you clean it...completely covered in ash and perhaps some creosote. Your window is being impacted as well. I've now had my stove for 17 months and every week during burn season I clean the glass. Some weeks are worse than others depending on how hard the stove has had to work. Same with the ash buildup on the interior.
No defect...consider it a visible sign of the pellet stove heating your home and saving you oil money!
You are correct. For the record Melissa...I wasn't suggesting that ash buildup on glass with a fire raging was anything unusual, or a defect. My point was that after the stove has been cleaned, and the glass has been cleaned, the haze that I posted a picture of always comes back when the glass dries, even though it appears to be clean.
thank you Steve. I was responding to JMart's comment that he wondered if the glass is defective I was not responding to enigma. I already suggested to enigma that he try Rutland glass cleaner.The haze he is talking about is there right after he cleans the glass (if I understand the posting correctly) If that is the case, then the haze isn't a normal condition because he hasn't burned any pellets on the freshly cleaned glass. His cleaner isn't doing the job.
Rutland cleaner contains silicone, that's why it can make the haze disappear.One thing I did notice in my very short time using a pellet stove.
After getting the glass clean, I wiped it with silicone lube from a spray can.
(It was Liquid Wrench silicone spray). I sprayed it on a small piece of cloth,
wiped it on the glass, let it stay wet a bit, then wiped it off completely.
Now, when I wipe the glass when I clean it, it is MUCH clearer with little effort..
I expect I will do that every time I do a good clean after shutdown..
Dan
My tech said to never use windex due to the ammonia in it.?As someone said earlier. Get a damp paper towel dip it in some of the fly ash and wipe it down. Then finish it off with some windex. I was just using windex then I read about the ash trick and first time I was impressed how well it worked!
Don't know but he said don't use it.Hmm what does the ammonia do?
Yea when she's shut down I get a damp paper towel do that about three times by the third shot it's nice and clean.perhaps the ammonia can weaken the glass or maybe the glass has some form of coating and it weakens it.im in the eyeglass field and ammonia on drill rimless glasses is one material will cause small cracks in the corners.Maybe affects the glass when heated up. Now that I tried trick with the ash I can go without the windex. Before I had to scrub hard to got the brown streaks off. Last week was the first time I tried the wet ash and it came off easy. Then just a quick wipe for final cleaning
Dip your wet paper towel in ash and wipe, it will remove the haze, then use a few dabs of Rutland to Polish the glass and provide a slick surface that the ash will not stick to as easily.I'm willing to listen to theories, Jack. Again, I simply use a clean paper towel with cold water. When the glass is wet, it looks clean. When it dries, that haze never leaves. Definitely seems odd to me. Who knows...maybe I have a defective piece of glass. We'll see what happens after I try the Rutland glass cleaner.
