Hello...I am new to the Forum..I actually joined because of you feed back on the PB105. I am looking at putting in a Pellet Boiler system..I was wondering if you put in water storage since putting in your system.. In reading they say that this a great way to store the heat. Your sqft dies that inc. your basement? I have a log home with 6000 sqft inc basement. So not sure BTU output of PB105 would do the trick..I am told it will but highly recommend water storage. I am looking at either going with Harman PB105 or Viadrus Hercules ECO. Any feed back or comments would be appreciated...thanks...KenMy settings are:
Max Temp 185 Min Temp 150
Auto Ignite, Old style Cartridge Ignition w/ 6 RPM feed motor
Feed Rate 4
Dip Switches : off on off
How many pellets are you burning a day?
1-2 bags a day, depends on outdoor temp. and wind speed
What size is your home?
2500 ft^2 set at 70 degrees
Do you have out door sensor hooked up? If not why? no
Do you have outside air kit installed? no
How long have you owned your PB105: 3 Years
Problems? slight bump forming in burnpot (still original)
Venting: directly into chimney
"Another issue i seem to have is the temp guage on the pellet boiler seems to be off. I have max set at 170 but it didnt shut off until about 185"
Do you have the aquastat in the top of the boiler or in the back of the DHW coil? Make sure the tip of the thermocouple is making direct contact with the bottom of the aquastat well, if there is an air gap between the thermocouple and metal the operation will be off. My gauge was off a little bit too, I "calibrated" it by unscrewing the plastic cover and moving the needle with my finger, over-traveling it in the direction it needed to go until it sprung back to where it was supposed to be. Now it works perfectly. It is really a cheap gauge I wish Harman would have included a higher quality piece.
"What kind of brush do you scrape the heating tubes with? How often do you scrape them with a brush?"
I found a "bottle brush" in the hardware store that works well and gets way up in between the tubes. I clean the tubes at least every ton when I do a full cold shut down and clean. I clean it a little more often now when I shut the boiler down because it gets to 60 deg + outside and am using a lower quality "shoulder pellet" now. Here is a pic of what the brush looks like:
There should be 1 screw on the outside holding the ESP in. You just shut off power to the stove, remove the fan cover, take out that screw, and slide out the ESP. Then you just clean it off with a damp cloth or paper towel then a dry one and re-install.i have the red wire esp, how do you go about checking it? Isnt it attached to the inside of the pipe? They have it just above the blower
Hello...I am new to the Forum..I actually joined because of you feed back on the PB105. I am looking at putting in a Pellet Boiler system..I was wondering if you put in water storage since putting in your system.. In reading they say that this a great way to store the heat. Your sqft dies that inc. your basement? I have a log home with 6000 sqft inc basement. So not sure BTU output of PB105 would do the trick..I am told it will but highly recommend water storage. I am looking at either going with Harman PB105 ..................would be appreciated...thanks...Ken
Very happy with the Thermal Mass "storage " my home has. thanks for pointing that out.One thing to keep in mind is that a log home has its own "storage," after a fashion, in the thermal mass of the log walls. It's a widely-touted selling point for log construction.
