We just moved into a house 3 weeks ago that has a Harmon PF100 furnace that was installed back in 2008. I'm having a heck of a time with this furnace and getting ready to call it quits with pellet heat. I had the place that installed it out to look at why it won't light and it lit for him while he was here, when running in service mode but only after he moved some of the pellets around in the burn pot. I can at times get it to light when in Automatic, when set to Auto light but it isn't consistent.
When the gent was out cleaning it/helping me figure out, he said that the feeder wasn't doing a 3 minute 20 second feed on startup which is what he expected. If he pulled some of the pellets up higher in the burn pot, it lit within a few minutes so he thought the igniter was fine, and suggested adjusting the dip switches to increase feed time on start up. He set it up by 1 adjustment and it still only runs for like 2 20 before the feeder stops.
When it does burn, it will run as expected to heat the house for the night and into the next day but while we are away at work, it seems to stop working the last few days in a row and the house temperature drops down to the LP furnace setting which we keep around 60. I have the wall panel set at 69-71 on the Harmon depending on the day as I play with it, but to no avail.
When it stops during the day, it flashes a 5 blink error when I arrive home - which I understand means it didn't fire in a set number of cycles. One time it had stopped and wasn't blinking a code.
It is like the feeder doesn't run long enough to get pellets in the proper spot to ignite, and then on a second try it over feeds the burn pot and raw pellets dump overflow into the ash pan and possibly because of the overfill, the igniter won't light them.
The service tech indicated that it was really clean, and he didn't even clean it while out because to him it looked like it just had been gone through. He checked the draft at the exhaust outlet and it was blowing plenty of air so airflow doesn't seem to be a culprit.
I'm at a loss, I have half of skid of pellets that came with the house, and when it works they produce great heat, but i'm sick of waking up to a cold house or coming home to a cold house. Does this sound like a bad panel that the feeder isn't running long enough even when adjusting the rate +20? I'm at a loss whether it could be a sensor, or control board, etc.
I'm losing my mind here wanting this to work, but afraid to start randomly buying parts to attempt fixing it.
When it was running it seemed like we were burning roughly 2.5 bags a day to get between 67-69 degrees in the house. Its a 2 story colonial with about 2250 sqft upper and 600 finished basement. Is 2-3 bags a day to be expected?
Thanks for any help offered
