Harmon Invincible
Bkins
623
Jersey Shore
15 year old insert. There is a gasket of some type that is mounted on the slide rail of the insert. Mine are torn up badly and need to replaced. They look like a flat door seal gasket. About 1" wide or so. Does this need to be a heat proof gasket or can I use a heavy webbing with the same thickness?
If the hopper lid gasket is missing parts will this affect the operation of the stove?
On the rails I used graphite when the old gasket finally fell apart.
nah....the gasketing is there to make the unit slide out easier...graphite will work, but you can replace the gasket as well......they dont hold up really well.
I will try the graphite since the gasket seems to be hard to find. I had asked about the hopper gasket because parts of the one on the insert I just got are missing. I am going to put a new one on during the rebuild process. I was just wondering if some of the eratic things I saw this stove do when I went to look at it could be cause by the missing chunks of gasket.
Thanks for the help.
