Harman Zero Clearance Cabinet Manual
Irish916
135
Eastern PA, Southern Poconos
Does anyone know where I can find the install instruction for the Harman Zero Clearance Cabinet, Part # 1-00-574323. This is the ZC box for the Accentra 52i. The manual for the 52i says the manual for this ZC box is on Harman's website, but I can't find it. I need to get the rough framing dimensions for this box. If anyone has the manual or knows where I can get it, please let me know.
Looking at the manual on HHT's website, the 52I insert being installed into the zero clearance cabinet PN, the instructions are with the zero cleance cabinet. This info is from page 12 of the 52I manual..
Installing the Accentra 52i Pellet Insert into a Harman Zero Clearance Cabinet
If you don’t have a factory built fireplace or masonry fireplace, the Accentra 52i Pellet Insert can also be installed into the
Harman Zero Clearance Cabinet, Part # 1-00-574323. This is the only permissible way to install the Accentra 52i Pellet
insert
without a suitable fireplace. After the Harman Zero Clearance Cabinet is installed, type PL vent pipe, wall pass-throughs and
terminations are used (Note: Flex pipe is not approved these types of installation). Detailed installation instructions are included
with the Zero Clearance Cabinet. These same installation instructions can also be found on-line at www.harmanstoves.com.
Below are two sample installations using the Harman Zero Clearance Cabinet.
PL Vent Pipe installed through a ceiling. PL Vent Pipe installed through an exterior wall
Harman
Thanks. I noted that document as well. I just can't find the rough in specs for the ZC Box.
insert
Harman
Thanks. I believe that is the ZC Box for the old accentra. The part numbers are not the same.
FWIW- I called Harman and they e-mailed me a copy of the manual for the ZC box for the new Accentra. So if anyone needs a copy, I can send you the PDF they sent, or you can contact Harman directly.
I've received a few requests and finally figured out how to post the PDF. So here you go!! :)
  • Accentra 52i ZC Cabinet Install.pdf
can anyone tell me what the cost of the ZC cabinet is for th 52i?
I paid about $319 for my ZC cabinet. Install was 9/20.
