I have seen a few forum posts that had a problem with the PF100 flapper plate in the outside air connection, sticking. Would not matter if you had outside air hooked up or not it would still restrict the airflow through the burnpot. If I remember correctly the problem was corrosion on the pivot ears of the flapper plate or one of the ears might have had a bur not cleaned off the plate at mfr. I believe the fix was to clean up the ear and put a small drop of oil on both pivot points. Then make sure the plate would swing freely
In the picture the arrow is pointing at the flapper (damper) plate.
![[Hearth.com] Harman PF-100 flame shape and behavior [Hearth.com] Harman PF-100 flame shape and behavior](/talk/proxy.php?image=http%3A%2F%2Fi357.photobucket.com%2Falbums%2Foo18%2Feewing_01%2FOutsideAirconnect.jpg&hash=0b92509f4d266ce4f1193d0b19b61bc4)
