alfio said:mgambuzza said:With the temperature drops below zero happening, it brings up some of the shortcomings of my current stove. The Thelin Parlor Pellet can barely keep my basement - concrete - 1300sq ft - open floor plan - no insulation - at 64 degrees with stove at full tilt.
I was considering the following options - Harman P61 or the Magnum Coal Stoker. I don't want to consider wood due to the maintenance, constant adding of fuel, and being away from the house 8 - 10hrs a day(the fire would go out and the dogs who are in the basement would freeze). I was originally considering the Mt Vernon, but have a Castille on my first floor and I am not overly thrilled with the performance and quirks of this line or product.
I have made some incremental investments within the past year on the basement stove, and want to make a final investment that will last me numerous years. They are both in the $2700 price range, so price isn't a determining factor. I don't want to buy one of these and a year later kick myself for not buying the other as it performs better under adverse conditions.
Hi, i have a p61 and i heat approximately 2000 sq feet , 700 in the basement and 1450 first floor . and it a hard time keeping the house at 65 degrees , i would consider the p68 or the magnum coal stoker .The meg. has more btu's + you can run a duct from it . good luck
If the p61 cant heat the home, I seriously doubt the p68 will do a much better job at only 7,000 but/hr more capacity. The Mag Stoker has quite a bit more capacity, but would of course require a chimney.....and yes, yoc an run a duct to the top of the mag stoker as well....has a 6" cutout there.
