Yes! That's exactly what I need. Where is that screw?It sounds like your stove is over drafting a little bit.Pellets stirring is one thing, blowing out is another. There is a trim adjustment for draft control. The ultimate proper method is to adjust that with a meter but you can turn the trim down a little with a screw driver just enough to stop the pellet flight. I adjusted mine that way. I just put a tick mark on the face plate from where I started so I could get back there if something went wrong. In my case my flames had white tips, so also over drafting a bit, I turned it down less than 1/4 turn of the screw and the tips straightened out.
