I just bought my first pellet stove and it's a Harman P61. I have read all the manuals and also read a recent post explaining in detail how the controls work. What I don't understand is the feed rate. Why is there a feed rate knob when the stove, set to either " stove mode" or "room temp mode" is going to add or decrease whatever it needs to reach those temps that you set.
So far I have only used "stove mode". First I selected "7" and left feed rate on 3.5. Just to see how things worked I changed feed rate to 6. The stove was hot as expected but it never even came close to spilling pellets over the pot. They are easy 2" away from the edge. When I turn the feed down to 1 it's the same thing. I hear all about setting your feed rate to the right setting or you waste fuel or get improper burn with lots of smoke. I can't get them to spill if I wanted too!
Next i tried "stove mode" to 2 and left feed rate on 6.....stove cooled down but still no pellet overflow. Basically my feed rate knob does nothing that I can notice which is exactly what I would expect when the stove is automatically adjusting itself anyway.
Thoughts? Thanks.
Thoughts? Thanks.
