Hello All,
I have an older (11 years) P61 that I've just last year had a few parts start to wear out and need replacing. One of those parts was my distribution (blower) fan. I had replaced it at the beginning of the season in 2016 but quickly returned the fan to the dealer as the horrible noise it made was making me crazy. By the end of the season my old fan finally bit the dust and I had no choice but to put another new one in. the same thing is happening. once the stove gets going and warmed up the fan starts making a noise that I cant describe other than that noise the TV used to make when the channels went off the air at night.....ya you know the noise...its horrible
( if you done know what I mean...google channel off air sound....) the sound only changes slightly when moving the temp setting from low to high..just changes the volume of the sound.
Now the weird part here is that if I turn the stove to test mode the noise will stop...which I can only assume is because in test mode it cranks everything to full power? I say this because the distribution fan light gets brighter when the sound goes away.
I had also thought that perhaps the circuit board was part of the issue so I replaced it as well. That just caused a whole host of new issues, the distribution fan never "ramped up" it was always on minimum, unless I turned the thermostat up from the current setting to make the stove call for heat. typically my stove can maintain the temperature without having to dump a bunch of pellets into the burn pot and go into high burn. so basically with the new board it never turned the fan up. That compounded the problem as then the heat didn't move around therefor making the basement even hotter than intended.
if anyone has any thoughts on what could be causing the issue with the fan or if you've experienced the issues with replacing a control board and figured out a fix I'd love any advice you can offer.
( if you done know what I mean...google channel off air sound....) the sound only changes slightly when moving the temp setting from low to high..just changes the volume of the sound.Now the weird part here is that if I turn the stove to test mode the noise will stop...which I can only assume is because in test mode it cranks everything to full power? I say this because the distribution fan light gets brighter when the sound goes away.
