Really Hot, your ESP probe measure the exhaust temp of the stove, and is used for stove temp mode, and tells the stove if it is getting too hot and when it is cool enough to shut down when you turn the stove off.  It is located in the exhaust tube behind your ash box.  It can be accessed by removing the right side panel of your stove and looking for a wire and a hex head screw in your exhaust pipe where it comes out of the stove. Personally I like to keep that probe clean since I run my stove on stove temp most of the time.  I Like to clean it every time I empty the ash box, and perform a thorough cleaning of the stove.
Lousyweather, still waiting on the dealer to come with DDM and draft guage.  Says he'll get here as soon as he can, been a week and a half already.  When the hopper is empthy of pellets the slide plate looks as clean as a whistle, is there more to it than what you can see?  The stove works great on room temp mode, so that led me to believe feed was not a problem.  Also, when the feed motor is running, the pellets are feeding.
I thought that I had got the stove working better by adjusting the draft voltage, since it had never been set since the new motherboard this fall.  But, this was just temporary, it is still surging, and will not throw constant heat or flame on stove temp mode.  I can watch the digital thermostat in my loft go up when the stove burns a good flame, and start to drop when the flame gets low.  I did adjust my temp setting to a little above 80, from 75.  It is still surging, but does not burn quite as low in the pot on it's low end of the surge, and burns a huge flame on the high end.  It is also not burning very clean because of this surging.  burns a great clean bright flame on the high end, on the low end is dirty orange, flickers, and produces alot of fly ash as the pot fills back up again.
I don't know, I am at a loss, I have been dealing with this for the past couple of winters, and getting educated on the way.  If my dealer does not find anything wrong with the probe, and has no other solutions, I am going to request a new stove.  I doubt he will go for this, my three year warranty is up just before Christmas.  If I do not get a new stove, I will explore the cost of trading on a new P61-A.  I loved this stove when it was working like it should.  And I know my problem is isolated, especially since I have not read of anyone having the same issues.
