I have had my P43 running for about 3 months now with no problems whatsoever until recently. During the recent cold wave, which saw my local temps plunge to -33F, a rather odd thing has happened. The flame will change from it's usual and typical pellet stove flame to what I can best describe as a rather "lazy" wood stove type flame with smoke and soot on the inside of the glass. The stove temp will increase from it's usual 500-600F temp (measured on the side of the fire box) to over 700F and with a slight smell of "hot metal".
The stove is cleaned completely every week and the burn pot is scraped at least twice a day or more while running. Today the problem started a half an hour after the burn pot was scraped and cleaned with a feed rate at between 3 and 3.5. So much for a dirty burn pot theory.
I am running ICC Excell Pellet Vent pipe 4" with an EVL of 19. I have a 3" outside air intake of approx 10' in length with 3 90 degree bends from intake to stove attachment.
Given: So far this has only happened when the outside temp is well below zero. This morning it was around -11F when the problem occured.
I have temporarily disconnected my outside air intake with the thought that if this only seems to happen when it is below zero, than possibly it could be the cold air causing some problems. ?????
In the pic below, the vent pipe rises another 4 feet and exits horizontally through the wall.
My dealer says it is dirty pellets causing too much ash, but cannot agree with that. First of all, as I stated, we clean the pot at least twice a day, and secondly, doesn't Harman brag about how good their bottom feed system is in burning all types of pellets?
Any thoughts on this would be greatly appreciated.
