BJN644 said:Just to comment on stove size. I have an older cape style home with fair insulation, about the same sq. footage as you, stove is centrally located on the first floor. I don't find the Oakwood to be oversized, it's very contollable and will damper down nicely and heat the whole house on the coldest nights. Before the Oakwood I had a Hearthstone phonix, it would not do the job when it was cold out and would not burn all night. As I said before the Oakwood is a 24/7 burner much like a cat stove and probably not the best bet for a partime burner. I would probably have the Jotul Oslo as my next choice.
BeGreen said:If the Oakwood is doing a good job and not overheating a 1000 sq ft cape then I suspect the building is not all that well insulated or is somewaht leaky, even accounting for the colder climate. But thanks for the good feedback. Perhaps the Oakwood idles better than I had thought. What are your average January temps?
Potter's actual (oil) fuel consumption indicates that the home has very moderate heating requirements. Figure maybe 30,000 btus max? I agree an Oslo could work, perhaps the Oakwood too, but it may be on low idle or burning short fires a lot of the time which isn't the best for efficiency or the cleanest burning. It's a tough call in a small, tight place, but I'm sticking with the Woodstock Palladian or Keystone or a small PE Alderlea as being the perfect fit and a Castine if it's a Jotul.
BeGreen said:Thanks a lot for posting the quick review BJN. We don't hear enough about this stove so it's really helpful. Good to know that the stove is working well for you. It seems like in a small place they could have it heated up before getting a good secondary burn. That would be somewhat inefficient, no? But for a larger home where it will be burning 24/7 from Oct to Mar it sounds like a great stove. Can you post some pictures? How long have you had it?
I also see you have the Drolet Myriad. How do you like that stove? How has it burned for you and what are typical burn times with it?
