Hey,
I just recently purchased a Harman Invincible pellet stove second hand from a guy I work with. I'm sure many of you are muttering something about me being one of those newbies that causing the pellet shortages in New England
) - I would be to. I've been impressed so far with how much heat this stove can put off. I am also learning that the right pellet makes ALL the difference. I have couple questions about the stove and about heating with pellets in general.
1st question:
The controls on the Harman provide control over the
-pellet feed rate
-stove temp/room temp control (ranges from Low to High for both room & stove temp)
-Temperature setting (dial has a range from 50 - 90 degrees and is numberd 1-7)
I have the manual for this model but I'm still a bit unclear on several things. According to the manual, when I set it to run off "stove temp" the cumbustion and distribution fans should remain constaint after the appropriate stove temp is reached and then I just need to find the appropriate feed rate. What I don't know is if the Temperature Setting gauge has any affect at this point. I suspect that it does b/c when I crank that gauge up, it seems that the feed rate increases. Anyone know for sure about this?
2nd question:
Does anyone have experience with what the pellet consumption should be like on this model? I am burning anywhere from 1-1/3 - 1-3/4 bags per 24 hours. I'm able to heat an entire 2200 sq ft house with that but I don't know if that's a lot of pellet or not. If it is excessive, is there anything I would need to replace or repair to help with this since it was not purchased new?
3rd (and final) question:
I'm able to heat my entire house but not evenly. I have an old farm house and it's basically a collonial, 2 story house with about a 600 sq ft single store attachment. The attachment is the hard part because I only have a door way to blow heat through. I've been using a couple fans to try to circulate heat but I'm very curios what's available for this purpose, what resources are out there and mostly what you all are doing to solve such a problem.
Thanks much for any and all responses
Jim the Newbie
1st question:
-pellet feed rate
2nd question:
Jim the Newbie
