ok....[It's Tonyray but no harm/no foul.....Hi Tom Ray, After having read many of the posts, in my opinion, probably the most likely cause of the problem is
ash on the ESP, causing it not to read as high as heat as it should. My solution for now is to start the stove on
constant burn #1 until I get a big fire, then adjust upwards.
I know some people use a low feed rate on room/auto like # 2, ESPECIALLY if using long pellets to get started but that just masks your issue which hopefully is
a dirty ESP...
. Even if I didn't do that (I forgot or something), the floor always has such a build up that I have to get the ash scoop and clean it up anyway, so not a big deal. Don't know why Harman can't make the pan a bit longer so that it actually goes past the edge of both shelves so ash doesn't go everywhere. I never had that issue with the Hastings - the one thing it excelled at compared to either the P61 or P43.
