Hello,
Did a good cleaning on the stove and ran a brush up and down the chimney. Pushed the stove back in and fired it up, started up as usual. After running a short period of time the flame died down to no higher then the burn pot, pellets kept feeding and within a hour it went in to shut down mode and shut itself off. The status light was on and blinked 6 times, per the manual it says poor or incomplete combustion and gives the following suggestions.
#1 Blocked or partial blocked flue.
#2 Blocked or partial blocked air inlet
#3 air chamber under burn pot may be filled with fines of ash
#4 holes in the burn pot filled with carbon buildup
#5 Combustion blower fan may be clogged
#6 no fuel in hopper
Chimney was just cleaned and there is noting in the chimney, air inlet was checked and is not blocked. Air chamber was checked and is not blocked. Burn pot holes are not blocked, combustion motor was a little dirty but was cleaned. Hopper is 3/4 full.
Do not know what else is preventing the stove from running and is shutting it down. Any sugge3stions would be greatly appreciated.
