Hello, I'm referencing this older thread:
www.hearth.com
I'm in the same boat. Have an Accentra 52i and replacing the burn pot with the new revised one. I have the restrictor plate behind it and if you use the new gaskets that come with the new burn bot version and since it requires two, one in front of restrictor plate and one behind, these gaskets are much thicker then the original ones and it cause a slight gap between the burn pot and stove where the auger is pushing pellets in. I have reached out to Harman but still no answer on if the restrictor plate is required with the revised burn pot.
What is this restrictor plate behind my Harman 52i burn pot?!
I'm replacing the burn pot on my 52i, and just found this restrictor plate behind it?! I was not expecting to find this plate, and am now wondering if it even needs to be there. The throat for the air (bottom port) is small than the throat on the stove body, hence the name I guess. We bought...
www.hearth.com
