jackhammer
Burning Hunk
Jackhammer,
I was in your shoes last fall so don't sweat it. It will take some time but you will figure out what works best and when for your set up. The 61, 68 and older PC 45 will eat some pellets vs. smaller BTU stoves as mentioned. The older 45 is the same size and platform as the 61. Best thing I can recommend is setting it to 3.5 feed rate and room temp auto and the temp dial where you want it. Don't let the igniter hype worry you at all. IMHO that is ridiculous.
Get used to how it operates and then you can fine tune stuff. FYI I just switched from room temp auto to room temp manual this morning. I have my feed rate at 1 and set to 4.5 on the temp dial. This set up I always have a flame and the inside temp stays right where I want it for now. This is what works best for me now but the knob twisting can get goofy and confusing. I set it here so my distribution blower runs all the time which I like.
There is a lot of confusion on this and I am trying to figure out why. Read my post above. Is your stove a new one? There might be a difference in older and newer stoves is my guess. These guys know their stuff well but as you can see Cory and myself are operating differently. I am assuming it is a difference in the years the stoves were made. Not sure but the only plausible explanation I can come up with.
I would not try to compare your new stove to even a 20 year old Harman let alone another make.
My stove is new. I know the Harman is bigger and better so it will burn more pellets. The high consumption issue was overnight in room temp mode, temp on 55 or so, manual igniter, feed rate of 4. Burned half a bag and I don't think the stove had to fire up at all, it wasn't that cold and the house was in the 60's when I got up. Logic tells me if I turn the feed rate down, I will burn less pellets, and during this shoulder season, it sounds like a good idea to me. When it gets cold, I'll go to a feed rate of 4. By the way, my temp probe was taped to the back of the stove by the installer, who came highly recommended with lots of Harman experience. This seems to be another point of contention! But like you said Bags, I'm not stressing! It'll all work out.
