Have no fear about heat distribution.... I'm a bit farther north than you and I heated my house solely with that same unitThanks..still itching to fire it up. Interested to see how it heats this winter. Hoping the heat distributes well through the house.
Looks Great!!, you did a awesome job!!, been thinking about buying a new stove, i know, i cant kill my Whit and the Harmen would be the next best stove to buy, imaginge having a Igniter and a t-stat??.....noway!!
Remember the stove is a space heater it heats the room it's in and hopefully the rest of the house, dont know your layout but my other rooms are 10 degree's colder away from the stove, it all depends on outside temp and most important dewpoint.
But your in MD heck palm tree's grow there, well seen 1 at Ocean city's boardwalk.....lol
Have fun and stay cozy. That sounds like smart stashing: you never know if a polar vortex will rear its ugly head. Having a head-start on next year's pellet stash might save you some panic. That long wire is the sensor. It detects temperature at the bare end and compares to your specified minimum room temp. It can also be replaced with a full, fancy thermostat that responds to timers and Wi-Fi control and the current trading price of Brent Crude, but keeping it simple has its advantages. As best I can tell it will:
- run one cycle of the stove
- keep running until reaching the target temp
- finish the burn cycle including the long cool-down
Just be don't put the sensor in an unusually hot or cold spot. It would never shut off if you put it against a window and turn off prematurely if touching the stove surface. I have mine tucked under the stove (against the floor and with no wire visible) so it is reading the air taken in for circulation. That's not a perfectly accurate reading since we aren't lying on the floor, but that just means adjusting the temp dial accordingly. We run it exclusively in room-temp mode, turned down before bed and up first thing in the morning. I'm told these self-babysitting abilities are one of Harman's biggest advantages. As one user told me, "Why not use room temp mode? That's what you paid extra for by getting a Harman."
I was wondering because when you watch the video it says to put the sensor about 20 feet away at a height of about 5 feet. If i go taping a bare wire to the wall the lady will not be happy so it will stay under the stove.
Have you pulled your insert out for cleaning yet? Anything to be prepared for? I still need to build a rail kit.
Your contractor / installers did a very nice job and you paid a very fair price for what was done. Trust me, I know these things. I am a contractor. You have an extremely nice looking set up there and will love your Harman or pellet burner in general. That is my kind of look for a fire place. Clean, rustic, natural, and rugged!
Very, very, ..... Very nice! < said with an accent)![]()
Nice install! had mine installed last week. hasn't been brutally cold yet, but have fired it up a couple mornings to take the chill out. all the women-folk of the house (wife and 3 daughters, 3mth, 3 and 5) flock to that thing like a damn magnet. i think i've started something awful...
I'm working on my next project now, framing and insulating the basement. That's where the stove is[/quote
That will help quite a bit. The concrete or masonry walls soak up a lot of heat thru thermal mass. Get a vapor barrier (plastic) in between your masonry and the insulation. Many times I will glue > (a few dabs of Liquid Nail or such) 1/2 " Celotex (4' x 8' sheets of foam insulation) onto the existing basement walls, then frame the walls and insulate between the 16" O.C. studs. I foil tape the seams. Costs a bit more but serves as a barrier and also adds some R-Value. Just a suggestion or alternative. You will also be fine with plastic behind and batts in the wall stud cavities. I do quite a few basement finishes.
You are doing yourself a big favor down there. You don't even need the drywall or interior wall finish and can do that later. Just get the vapor barrier and insulation in to gain the R-Value. This would give you time to pull wiring etc; if you don't already have it planned out. Have Fun and Good Luck!
The wife and girls love our stove too! I have to admit, I like it more for numerous reasons. A LOT MORE!
