Good move. Iv found super deals on Regular cab, 4x2 trucks just a few Yrs old. Since everyone seems to want the 4x4 Ext cabs, the Regular cab 2 w Dr. prices come down fast. IIl be keeping my 20 yr old 4x4 ext cab 3/4 ton so i dont need another.No, it is used. A 2013 model with the steel body, 3.5L ecoboost motor.
![[Hearth.com] Half-ton pickup redux [Hearth.com] Half-ton pickup redux](https://www.hearth.com/talk/data/attachments/200/200081-0f65e316363de42f5a7bfe665f42bacd.jpg?hash=264YMBq51p)
That first year of depreciation is a deal breaker for me. Im finding 2 to 3 yr old trucks for half price with 20 to 30 k not quite broke in for a truck. Ill probably get a 30+K truck for 15.I always buy new,
Greg
I always buy new, and cheap simple single cab stick shift 4 x 2 half ton's are my work truck of choice.
The last one was $10k cash out the door. I used it for 17 years, sold it for $4k and applied the money to a new 2012 single cab, for a net cost of $15k cash out the door.
There's hardly anything to go wrong with them because they have no expensive options. It has metal non electric door keys and the windows roll up and down with a hand crank. With a small engine and a stick shift it averages 24 mpg loaded with materials. And it earns its keep because it gets used every day for work.
Greg
Sometimes it makes sense . Like when you get a pile of incentives and 0% interest. And some trucks dont depreciate that fast like the standard cab 2Wd ones do. Ford gives load of incentives lately.I don't consider $6k in depreciation amortized over 17 years to be taking much of a hit...
...and I love buying brand new trucks.
Greg
The problem with running a 1/2 ton as a 1 ton is, no matter how much you beef up the shocks, springs, tires etc, the rear end, axles, housing, bearings & seals etc, are rated for 1/2 ton. Occasional loads would be fine, but constant 1 ton load, in time you're going to kill those gears, axles, bearings etc.
Agreed.That's a good point and I agree.
But most trucks I see around here are run with no load over 90% of the time. So in many cases it would make sense to have a 1/2 ton that could occasionally do the job of a 1 ton.
And absolutly people who use their trucks like that should have a 1/2 ton. Or better yet a car and a beater truck like me. Only use the truck when you need a truckThat's a good point and I agree.
In this area of PA, you also have to watch your back with State Police, who will pull you over and drive your pick up on portable scales and fine you right on the spot. PA state & municipalities are all about collecting fines to line the coffers, although technically they are not supposed to do it for state & local income, Yeah okayAnd absolutly people who use their trucks like that should have a 1/2 ton. Or better yet a car and a beater truck like me. Only use the truck when you need a truck
We dont see that issue here. If we did i would still be in trouble. My 1 ton is only registered as a 1/2 ton. And i am also regularly over a ton.In this area of PA, you also have to watch your back with State Police, who will pull you over and drive your pick up on portable scales and fine you right on the spot.
If you want a full sized 1/2 truck with M/T, I think you are stuck with one option and it's a diesel. .
Curious who offers this combination? (full sized half ton, manual transmission and diesel)
Oh boy. That is special. The common man can't even use a pickup with out harassment from the state. Sad times
 The newer 1/2 ton weight specs have been creeping up to the point where they equal the older 3/4 ton . Even tow ratings are getting higher ,some 1/2 ton trucks are rated higher towing than my 1995 Silverado K2500 . I think the Mfg. are beefing up the 1/2 tons so they can claim best in class ratings.The problem with running a 1/2 ton as a 1 ton is, .
