HAIRLINE CRACKS IN COMBUSTOR
Todd
11,437
NW Wisconsin
Checked my cat combustor this morning and noticed some hairline cracks in some of the cells. No crumbling or breakups, just cracks mostly about 1/4 to 1/2 inch long. Stove is only 1 year old and my wood is very well seasoned. Combustor still glows and seems to work fine.
Called Woodstock, they said that is the first sign of thermo shock, but if it still works and hasn't crumbled it doesn't need replacing. They usually don't start cracking for a few years. Thermo shock is caused by adding wet or snow covered wood to the fire and engaging the cat before the moisture is burned off. It's like sending hot steam through the cooler cat. I keep a weeks worth of wood inside next to stove so that can't be the problem. Maybe I engage the cat too soon, but my probe thermometer is always over 600 when I engage. Anyway, Woodstock says the cat is prorated if it fails before it's time.
Anyone else notice these hairline cracks in their cats?
Upon further review, some of the cracks go all the way through to the other side and there are more cracks than when I first looked. I called Woodstock again and talked to a tech trying to figure whats going. Could be too much draft, might install a pipe damper. They are sending a new cat free of charge. Great service!
That's what I call customer service. You know you could have gotten a less that stellar cat to begin with.
It may not have been caused by your stove opperations but atleast you know better to wait a bit longer before engagement
where did you buy the cat?
what do you think caused the cracks?
I understand that wood stored in Holtz Hausens causes that.
The cat is the original that came with the stove one year ago. I'm thinking that since I installed a probe thermometer this year, I was watching the temp on it and engaging in about 5 minutes. Could be that was too soon and was sending some steam from left over moisture in the wood up through the cat. According to Woodstock you should wait after reloading 10-20 minutes to make sure moisture is drivin out of your wood regardless of firebox temps. I was just trying to get the most out of my stove thinking the probe thermometer would help. Live and learn.
OH OH! MO you better check your cat. :lol:
