Damaged Cat?
I did a quick peace of mind cleaning yesterday, chimney wasnt bad, maybe about a cup of powder crud came out, cap wasn't bad either, I did take the flame shield off and inspect the front of the cat, this is my 3rd season on a ceramic cat, I have some small crumbles on the lower corners, I know i have a high draft especially when temps are colder, between the NW prevailing winds and chimney orientation, I need to operate with a damper to keep things in spec, the one thing you can check to see if your over drafting is fly ash build up, when I vacuumed the upper stove chamber, I also hit the back of the cat, heard lots of little clinging in the hose as the fly ash build up was removed, I also noticed when I made a new fire the cat was much more reactive, both the probe read higher and the glow itself was brighter.
The spec is .05"wc for draft, I tend to operate around .08"wc with the damper almost fully shut on the chimney side, without the damper I run about .18"wc or just over 3x recommended draft.
Reactions: Dieselhead
When trying to suck out your cat from the back, how do you get around the welded in steel curtain? Or does your model have that?
I have a small reducer nozzle, and I carefully worked it in with the by-pass closed coming in from the stove collar, used my cell phone flash light
Reactions: Highbeam
Some models have removable or moveable back pressure plates. Older models were welded in fixed positions.
BKVP
Reactions: moresnow
Might consider the 50/50 viniger, distilled H20 soak at this 3 yr point. Just did mine. The awakening is real::P Amazing results every time.
Nah, its working just fine and I also have 2 new cats waiting in storage for when this one finally dies, hoping to get a full season out of this current one.
