Gutters
Ahoragi
105
Western PA
Had a new metal roof installed by the Amish last year. We had issues with water running down the fascia and onto the soffits with the old shingle roof. It is a bit less now but still happening even though the water drips right into the gutters. There is quite a gap between the gutter and the new drip edge. We live in the middle of farm land so rain is horizontal most of the time and it appears to hit the back of the gutter and in this gap which causes it to run down the fascia. I think the simple solution would be to get new gutters and raise them up and behind the drip edge?
My fear is the fascia board is rotting from all those years of water running behind the gutter and a few screws have pulled out. I will have to tackle that if so.
  • [Hearth.com] Gutters
  • 20260513_072752.mp4
    6.1 MB
Looks like a good setup already. You could get some clear sealant and seal the crack in between. Make sure it is draining as fast as it should to reduce the splashing. Some water will run off the face/front but there's nothing you can do about that.
Or get a roll of flashing, cut out sections for the brackets, and slide it under the drip edge and over the gutter back wall.
Or use PVC fascia?
Reactions: Whitenuckler
The house I had before this one was built in the 40's, and all wood facia and soffit. A few years ago I had a company put on new fascia aluminum, new soffit, and new gutters. In your case they would replace any rotted wood first, or as above switch to PVC for the fascia.
I did this on my garage to solve the same issue years ago and it worked excellent.
When I installed my metal roof on my cabin I bought a roll of the same colored metal and bent it so the top fit under the drip edge, the bottom was bent to an acute angle. So any water dropped off and didn’t run back onto the wood soffit.
