Im guessing since I didn't get any replies on the other thread Im supposed to start a new one(forum Etiquette?)
2 Issues
I just fired up the hearthstone and when I open or close the air control it really doesn't have any effect. It just burns Hot and fast which I believe is due to the ash pan. But before I installed it I checked to make sure the gasket was tight, by sticking a light in the ash drawer and looking for light in the box. Is there another thing I can do? I let the fire burn out and pulled the ashpan the gasket looks good but I pulled it out and reset it. It slowed it down but Im going to see if I can get a new gasket at Tractor supply today.
The second issue when starting the fire smoke will drift out the door when loading. Which could be from the way I start the fire (some paper,a little kindling start fire ,close door but not tight , open door ,add a little more kindling,(thats when smoke will come out .Not alot but enough to bother me. Should I just be loading with kindling instead of a little at a time so the chimney heats up?
The chimney is 6" double wall that stands 14' from the top of stove to the top of the pipe and that has a cap on top . Its also straight up,no turns in the pipe
2 Issues
