Have a Grizzly insert in the basement that has been a wonderful means to heat the area and provide secondary warming to the house and my wood working area (old garage). Now the blow is making sounds that suggest animals may have tried to set up shop in the base of the insert. The company is now out of business. It is likely that the blower system will need replacing. A summary of symptoms is failure to of the blower to start when switch is set to "cold" setting. Delay on thermal setting as well. When it does start the blower "screeches" and has two sounds: One suggesting a bearing problem and the other a "binding" problem. When the insert does come up to high heat, the blower works. HELP?
Grizzly Owner
Grizzly Owner
