Rhonemas said:I researched into the Flat Plate vs. Evacuated tubes and I decided not to go for the evacuated tubes. The arguments are higher efficiency particularly in cloudy & in very cold weather. That can be true. But, people who have them complain that when it snows, dews, or gets covered in ice since they're evacuated and don't let heat escape, they have to go out there and physically remove the snow and ice as it doesn't melt off them like they do with panels. I also saw that places do a square foot analyses comparison and show that the evacuated tubes are more efficient.
Good point on the snow collection - I think if we do end up with the evac. tubes, it would be to mount them more in the center of our roofline so they are less conspicuous (with less of them) but the only way we can do that is angle mount them to get best performance. Sounds like we'd need to mount them off the roof a bit to help avoid excessive buildup if we go that route - good advice.
The one other issue I'm not yet sure about is how we will route it - if I angle mount these where I'm thinking about them, I have a much shorter run to a place in my attic where I can feed through to the basement. The flat panels would have a much longer run since there is really only one place I can put them, meaning more install/plumbing work which might offset some of the cost difference.
Basically I'm looking at the same issues you are - higher cost, incremental performance advantage - biggest plus for us is more placement flexibility to hide them.
Certianly without a total of 50% savings from tax rebates, I wouldn't even consider that option for all the reasons you mention - once we get this project sorted out with costs, I'll post the details.
-Colin
