tlc1976
Skate bearings in this instance are just ball bearings. Similar size to those used on skates.
The alternative is bronze bushings.
On mine I have to disassemble part of the motor to get to the bearings. Hold it so the bearing is flat (shaft is vertical) and add some oil to the surface of the bearing. Rotate the shaft and it draws the oil into the bearing near the center.
I put a little oil into a pop cap and suck it up with an animal syringe.
