jmccown said:
Done a test fire on the stove tonight. Have a couple of questions. I put in a couple of handfuls of pellets in the burn pot and got them going and then placed a couple handfuls in the hopper. The exhaust blower starts right up and gets the flame going pretty good. But I noticed that the convection blower never did start up until I unplugged the unit and plugged it back up. Also, the air just got "warm" from the unit. It never did really get HOT. How long of a burn will it take to get really warm air from the unit? Is the convection blower on this unit driven by thermostat or something and only comes on whenever it reaches a certain temperature? After I shut down the fire tonight I never could get the convection blower to come back on. I just test fired out in my garage to see how it operated. Tomorrow or the next day I will be installing it on my home. Would like to work out all the bugs prior to then.
Thanks all,
Jason
Try a
couple of handfulls in the hopper.
As far as harman stoves there is a probe in the exhaust pipe that monitors exhaust temp and won't turn on the "distribution" blower till this reaches a minimum temp, I'm sure Englander could be the same.
As far as the warmth being blown out I suppose you could look at it from this perspective, If you hold your hand 6 inches above a lit candle how warm is it. Now if you hold your hand 3 inches above the candle is it hotter?
ie: The more productive the flame (closer to heat exchangers) the more heat is blown into the room, run a longer test and it should be ok.
Good luck
I'm sure ESW will be here soon, I'm just helping to throw it to the top of the forum.
