Got a load today at my shared log pile
clemsonfor
2,513
Greenwood county, SC
Cut a quick load today from the pile on a friends field.
  • Got a load today at my shared log pile
This is only across our small town of like 100 people. I drove about a mile at 25 MPH. So nobody worry about logs rolling g out on an interstate or anything. Still had some daylight under the bump stops. After all this wood is seasoned and dry ;-) I dumped it there almost a year ago!
Wow. That truck is loaded. Good springs in those Fords.
Think how much more you could get in there if it had sides on it;lol
Loose that cross bed box and you could really overload the truck!
And these are weak tired springs!! The truck squats with a tiny amount of weight. Seriously cause this wood was cut a yr ago it is way lighter than green cut wood, that's how there is so much.
This pic is sitting g on axle hard!!
Reactions: Snigg
$60 air shocks!! But what I'm thinking is that transfers lots of weight to shock mounts that were never designed to hold that kind of weight. That's the reason I have not put them on yet.
Awesome ! nothing like having wood piled logs !
Your thinking is correct, the mounts are not made to support weight.
Thats what I call load it like its rented !
sorry its been awhile since I bought a set (10 years). and you're right, but a ford ranger was never designed to haul 1000 LB of wood.
Even with 600lbs that's still a lot to transfer a part to the shock mounts.
you're right the right thing to do is get a bigger truck. I add 3 leafs to my 1/2 ton. It still rides nice, but has the ability to tow my 24' camper, and a bobcat.
I have one of these, see pic. But the ranger and trailer will get more in 2 loads for the same price in gas.
