Wow, I've learned so much since I started reading this forum! About 4 years ago, I started thinking we could fit an insert into our existing fireplace; took a while to find out it wouldn't work without extensive/expensive/impossible masonry and other work. Happy to have settled on a freestanding wood stove on the hearth in front and think I've found a good installer to make it happen. Now, getting closer to figuring out our stove options.
Starting with the house:
- SE Michigan, plan to heat as much as possible, esp this winter where we plan to be at home quite a bit
. Have reasonable access to firewood for purchase this season, and plan to cut my own in the future. We do spend a lot of time in living room and surrounds, but also don't want to get blasted out from the heat.
- 2 story victorian (?), built 1913, fairly drafty but has lots of character. Chimney run is about 35'. My installer says the game plan is to put in 7" ovalized insulated liner. I only want a rear venting stove to connect through the fireplace w/ block off plate. Lintel height is 31". Hearth pad likely needs to get extended, and maybe a heat shield underneath existing mantel (55" from floor).
- Main living room space is 16'x22', kitchen at ~12'x15' and dining room at ~15'x15' on the first floor. See very rough floor plan. Four small bedrooms on second floor, square footage is listed at 1600 sq ft but I think that includes the unfinished attic (have never figured that out).
![Getting closer...looks like Jotul vs. Hearthstone... Getting closer...looks like Jotul vs. Hearthstone...](https://www.hearth.com/talk/data/attachments/262/262242-17471987378c018b57fc4d2db4706123.jpg)
Stoves: shoulda bought before May is what I'm coming to understand. Limited to shorter rear-vent options. Current runners are Jotul F45 ($3k+), F500 ($5k), Hearthstone Castleton ($3k give or take on website, but installer isn't dealer). Interested in the Hearthstone Shelburne but price not listed on website leads me to assume its not approved yet? I also have a lead on a Jotul F3 for what looks like a good deal (brand new, $1100), but a long drive. Perhaps the F3 is just too small? Woodstock stoves have been ruled out for their looks, unfortunately (not by me).
- I truly am having a hard time deciding what level of functionality we want. Like most of you, I look forward to learning how to get the best burn out of stove, but still don't know about the benefits of cat/non-cat, soapstone, other technologies, etc. Hard to figure out what's important.
- Is it reasonable to have a concern about buying from a separate dealer than who will be handling the install, in terms of warranty and who to call if there are any issues?
- Any other issues I may not have thought of to verify with my installer?
Thank you
![gulp _g _g](/talk/styles/default/xenforo/smileys/gulp.gif)
Thank you
